Since a couple of month WD would stop upadting every 2-3 days. Now it is every day…
What happens is that the weatherlinkip stops sending data, or WD stops accepting it.?
An exit and restart of WD fixes the problem but it comes back a few hours later.
What should I do or replace? the console, the weatherlink IP?
Also to say the “program event log” does NOT produce any report…
All suggestions welcome…
Thanks, regards.
-= Guy =-
Weather-Display (10.37S-(b53)) has been working ok for years…
try a console power removal for 1-5 minutes, you could also check the network cables that connect to the console and the pc, the connection on the plugs may need a clean try unplugging and plugging in a few times (the connections can become tarnished over time)
also try updating WD to latest build which is currently build 96
do you happen to have the IP data logger set to send data to weatherlink.com ?
if so then do you happen to have WD set to release the port every minute?
(both those can cause problems if the time on the pc does not match the time on the weather station console)
its good the program event log remains blank
if something else is using the port it normally uses then that makes sense (you had not provided that info originally)
