Hi to you all
I have here a sabvision 2600 ipcam
And I am looking for the url ware I can see my live image from the camera
I know for a axis cam it is http://X.X.X.X:port/jpg/image.jpg
but this will not work on the sabvision camera
does anyone know the correct url
also into the Manuel I can find noting
greetings Gert
thanks but I have already the manual
and I have already the camera working on wowza en also with VLC player
only I can not find the image from the camera
Is this into the manual ?? I can not find that
for example Axis cam it is http://X.X.X.X:port/jpg/image.jpg
and for the Sab vision I don’t know ( that’s is what I am looking for )
You should be able to use the same connect string in WD that you use in your browser. WD will produce an still image from the video of your cam.
that’s a good idea
only I must also have the good url
http://X.X.X.X:port/jpg/image.jpg will not work
In a browser try
http://cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=[USERNAME]&pwd=[PASSWORD] or
http://cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=[USERNAME]&pwd=[PASSWORD]&
What did you use to connect using those programs?
nop also not working
thanks for helping
wowza server and jwplayer this je will see on my homepage working whit the axis cam ( WeerCamera)
so now I will do this with the sabvision cam all is working except the still image from that cam
and vcl is working whit a script ( this you will not see on my homepage ( its on test )
From the manual, have you successfully completed section 3.1?
