Hello,
tomorrow I can’t perfom forecast for all my sites, the error occured is in object
In attach a screensoht
Any idea?
Thanks in advance
I will add my 2 cents worth.
As I am currently in transition between selling/buying my current house and not uploading data to a website as a result. I have not bothered to worry about this issue (nor have I had time to report here).
My personal opinion (correct me if I’m wrong) may be down to :
1: New wxsim (http://proxy.wxsim.net/...Tom’s Data) being unavailable when we request it).
2: Slow Internet connections (Timing out) either Tom’s end or Users end.
3: I run wxsim-lite manually again before retry and resolves.
4: More likely due to my last point = a GFS Availability issue, which I suppose is what it states.
In my experience, only seams to occur every other day or at least once or twice a week or when internet is slow.
Sorry, thought I had better add a little more, dependant on how you have your alerts set up, ie. run regardless of error, wxsim will run over night and if the above issue has happened, you (again dependant on haw many times you run it) may see multiple dialog boxes as you have depicted above, one for each failure.
Kind regards,
Thanks for reply,
ysterday was still in error but today is ok.
Thanks for your help
