Hi I just uploaded the latest version of WD but cronweatherflow is not working. i.e all the readings are not being updated (maybe I shoud’ve stuck to the previous version)
that is strange
as that program has not changed
i.e check the modified date/time on the file (nov last year)
yes " 08 Nov 18" but the cronweatherflowconsole does not load when starting WD.
I used to be able to open it by clicking on it but cannot do it any more, although when I restart WD after a couple of hours it pulls in the weatherflow history except the wind but it does not updaate in the “current conditions” Then it goes back to the previous reading on the graph
Pls see attached screen shot
I have just tested and its working OK here
post a screen shot of the running cronweatherflow program
do you see any errors under view , program event log?
The problem is that the cronweatherdlow program is not starting when WD starts
Program event log output “access violation at address 000000000081FF5C, accessing address 0000000000000125”
if you could email me your settings files then I will test here
as I do not have that problem myself here in testing
OK stupid question but where do I find the settings text?
I did find a possible way around it, I made a copy of the current version and copied a version of cronweatherflow from build 297 into it. This seems to work but I have to manually start cronweatherflow, also windy is not updating :? (maybe because its in a copy)
is the version of cronweatherflow from build 297 have a difference in the file modified time/date etc?
settings files are WDISPLAY.INI and wdisplayftp.ini in
~/Documents/wdisplay/
Email sent
works here with your settings
but it might be your data…zip and email me your data files?
