Hi to all,
i don’t know if already asked before but if this a possibility to make weather display ifttt ready?
I would use weather values to control house thermostats (netatmo or others) and air conditioning.
Thanks in advance,
Alessandro
Hi to all,
Thanks in advance,
Alessandro
I have added MQTT support now and that then can be linked to home automation
there is another thread about that
Thanks Brian,
how about other thread?
I’ve tried by ifttt but i haven’t found any thread.
Alessandro
search for mqtt instead
I was just about to ask about WD and a IFTTT service then saw this thread, im not sure if my smart home setup works with mqtt, i have alexa (2 hubs), smartthings hub and Hive.
IFTTT does open up a world of integrations, ie,
IF raining THEN flash kitchen light blue
IF raining THEN close garage door
IF raining THEN Notify me
IF UV > 3 THEN close living room blind,
IF temp is > 20C THEN open greenhouse,
IF temp is < 10C THEN turn on smart plug (greenhouse heater)
heres a good one, IF solar > 900 THEN turn on smart plug, great for those with solar panels
IF humidity is > 65% THEN turn on smart plug, for a dehumidifier
Or using WD sunrise/sunset IF sunset THEN turn on smart plug (Smart Life) or Light switch (ewelink)
Perhaps one day, maybe?
Sure, you can do it with mqtt broker and Home Assistant
I use alexa not google
