Two first of month days in 7Day Rain
I posted about this last month in another topic about rain issues.
In View/Rain Chart there are two first of the month days.
See the screen grab.
Notes:- I am in Australia
10.37S93
Ian
I am still seeing problems as well with build 94 here in the USA…
i suspect it was to do with april only being 30 days
when I find spare time I will investigate
currently planting 1000’s of native trees over the coming weeks that I have grown from seed
Thanks Brian. Great work with the trees!
This issue also happened last month for me which was 31 days.
Ian
Worked correctly for me (USA) since your last fix
Roger
yes, I did work on and did fix an issue
and I suspect w0mbat did not have that fix in use
(so make sure to have the latest update)
but I will do some back testing of the april month change
(but I have a woofer here and have to keep him busy…in fact its currently too dry here to plant trees…its now the driest (in terms of rain total) year to date on record here now
so the wife is like…he can do gardening…the woofer is from France…we were pulling weeds…and came across an old cow thigh bone…I said to him, that is what happens to woofers who do not work hard enough…lol…he was confused…as said just joking! (I joke with people all the time))
All I could find on google for what a woofer is besides a stereo speaker #-o
[i]"Visitors, or
that quote should add, and use up all your internet bandwidth 8O
“and I suspect w0mbat did not have that fix in use”
I thought that fix was in build 93 which is why I ran that upgrade.
Nevertheless I will upgrade to the latest.
Ian
I will do some testing again
But it’s our wedding anniversary today
So not today 8O
Happy Anniversary!!!
I finally found some spare time to sit down and nut out this bug
and I have fixed it 8O
in build 96
Thank you Brian! Will install now.
Ian
At first I thought it was OK but there is still a problem.
There is no 31st of May shown. It goes from the 30th of May to 1st of June.
See attached screen grab.
Ian
Build 96 looks okay here…at least until June 1st ends…will see how it looks tomorrow…
[add] Now June 2nd and still ok…
Looks Ok here with bld 96.
Maybe it is because I am in Australia with our 9AM reset and other differences. I am using build 96 as well.
Today it is showing two 1/6 days and no 31/5.
See screen grab.
Ian
Another difference is your date format of day/month versus month/day…
i have now fixed a bug with the Aus 9am rain reset option for the change in month rain
in build 99
so make sure to update to that before the end of the month 8O
Thank you Brian.
Will download and install now.
Is there anything I need to do to ensure the Detailed Rain Records are correct?
During the last couple of months 13mm of rain showing on a day near the end of the month in the detailed records “disappeared”.
What can I do about this?
Ian
