Hello
I have a problem with the last few versions of the program- ver 10.37Linux303 and 10.37linux302.
After a while, the program closes often unexpectedly, for no apparent reason, or freezes. When WD freezes, the CPU is loaded at 100% and program can only be closed with kill command from terminal. I use the latest 64-bit desktop version of the program and Arch based Linux.
Program event log :
Access violation at address 000000000045E7BD, accessing address FFFFFFFFFFFFFFE0
Access violation at address 000000000045E7BD, accessing address 0000000000000000
wd_error_log.txt (322 Bytes)
what weather station type?
That is for stationless mode with option client setup - the data is from over the internet
This is the program event log after 15 minutes of work with the station type Honeywell/TE923W
Access violation at address 000000000045E7B5, accessing address 0000000300000003
ERROR: Access violation at address 000000000052EFDE, accessing address 0000002003480359 at time/date 00:35 03/05/19
ERROR: Access violation at address 000000000052EFDE, accessing address 0000002203080309 at time/date 00:40 03/05/19
this did not used to be a problem you say, or?
I will do a test here (with a weather flow station)
no errors here so far in testing
what do you have WD set to do every 15 minutes?
Nothing. Program event log is not problem for me. A problem is frequent shut down of the program.
I have a crontab setting that check for WD and memory overflow. When the WD is not started, cron start again WD.
Here is log from crontab script. How we can see for about 9 hours wd is restarted several times.
With the same settings of WD, previous versions of the program (version 10.37linux301) did not have this problem.
I like the WD program for Linux. I appreciate your support and efforts.
Have a nice day.
cron_script.txt (3.48 KB)
I have had it running for 6 hours here
getting data from a weatherflow station
and its working OK so far
no errors under view, program event log
maybe email me your settings files so I can test here
OK, I get the same error here with your settings
I do see that you do have set to create and upload files under the customise internet and file creation setup
try turning those that you have set up off until the error stops (it could be the tempwindtrend that is the problem, file #33)
I will do some testing here too
I also see you have set the detailed climate report and noaa report to update every 5 minutes
that only needs to be set to be updated once a day
it seems to be a problem with the creating of the 24/48/72 hour graphs (file #11) in the customise internet and file creation setup
try turning that off
actually it might be file #1 where the problem is?
make sure to change to updating only once a day the detailed climate report (see my post above)
there still might be a case where file #1 in the customise internet and file creation is causing problems
I will do more testing
Done. I set it up once at day - 00:18h.
I am still getting an error
its hard to track down
it could be related to the latest compiler version
I could try using the compiler version prior
I reverted back to the previous compiler version and its OK again
try a new download
