On Sunday I updated WD from v10.37S-59 to v10.37S-95. Running on Windows 7. Wireless Davis Vantage Pro2
ideally need more info about where and how you have that setup in WD and any ftp logs etc
Attached is the config of the webcam upload screen.
FTP log only seems to have the recent (last few hours) data from the working older version.
what you would need to do is
using the latest version
set a time to upload that is different to other times
then check the ftp log
but there has been no changes to the ftp program or this part of WD for a long time
I’ll get back to this at the weekend when I’ve a bit more time. I’ll update you then.
I have same problem after instal build 95.
Uploading only animatedwebcam.gif but as one last image.
jpgwebcam.jpg don’t uploading
In webfiles folder everything is OK. Every file was created like earlyer.
someone else had that issue with the animatedwebcam.gif upload
and I have fixed that for that person with the latest .zip update of WD
so try that
I instal latest .zip and same problem still exists.
After that I instal build 94 and everything work good.
OH
you had not said that for you the immediate previous version was OK for you
which means the fix I made for that one person has made things worse for you
I will need your settings files to test/fix
Hi Brian
just checked mine and the jpgwebcam.jpg has not updated on the website since 23 April when I updated build 94 to 95, the jpgwebcam.jpg is being updated in the download folder ok
try a new .zip update
Last .zip solve the problem.
