Davis Instruments 'WeatherLink Live'
ah, WD might not be picking up that data correctly, with your configuration
I will need a copy of the Daviswll.txt file
Here is a copy of my Daviswll.txt file :slight_smile: thx!
Daviswll.txt (2.21 KB)
OK,I see the problem
the windspeed data is in the second lot of data (second sendsor)
the first lot of data the windspeed data is NULL data
so I just need to detect that and then use the second lot of data
I will work on that and let you know
I also need the file
Daviswlludpdata.txt
for the real time windspeed data
Attached is a copy of Daviswlludpdata. Thank you so much!!
Daviswlludpdata.txt (751 Bytes)
OK, yup, the first lot sensor data is NULL for windspeed
so I need to detect that then use the second lot of data
got that sorted
use a new .zip update of WD, ready to download now
Looks like that fixed it. Thank you!!!
Still trying to get WLL to send data to WD. no luck so far. Here are my settings…
what shows in the separate running crondaviswll.exe program
not sure how to display it?
I tried double clicking the exe file. nothing happens.
it should be running in the system tray
click on the icon there
ahhh. got it…here…
restart that program so that it picks up the correct IP address
also use the latest update of WD
as there was a bug where the IP address was not saved if you have ticked VP station type as well as the WLL enable setting
THANKS!!! It is working now!
that’s good :slight_smile:
I have added ability for WD to get missed data from weatherlink.com
but you do need a pro account (and then set WLL to upload every minute)
and then you need to get the V2 API key and secret…but they have not made that publicly available yet…hopefully soon)
I’ve got a Vantage VUE with WeatherLink Live and I am testing it with Weather Display. All seems to work good but the rain it’s always wrong. For example, today, on the VUE I read 4.8mm and on Weather Display I read 6.1mm. I’ve selected on the control panel Davis Rain gauge is 0,2mm but when I close Weather Display and I open it again the 0,2mm is not selected anymore. How can I fix this problem?
Thank you.
Stefano
tick to use the console rain total :slight_smile:
I don’t have a console… :roll:
I have the right number of tick (24 in this case). Should be 240,2= 4,8mm but I’ve got 240,25416=6,1mm
