Hi just wondering if you should be able to copy and past the API from Windy into the setup page? If you can its not allowing it
also the link to the windy weather stations does not work i.e it is not clickable
Thanks John
you should be able to right mouse click into the edit box and select paste
It doesnt work but I have added the very long API the hard way an that worked
OH
I will check it out
there was another way → adding it to the settings file
anyway, good it is working
I tested pasting text from a memo
and that worked
so it might be instead a problem with the copying to the linux clipboard from the windy.com web site
I copied and pasted into a document and tried it that way but still not successful.
anyway I see my station on the map but there is no data i.e temp etc populating :?
see what shows in the sentwindycom.txt file
SUCCESS (partial)
invalid measurement values: ‘winddir’: 312ts=1555722960;
I guess that means the wind direction is wrong? :?
there is a & missing
I fixed that the windows version
but need to do that for the linux version
I will do that now
but all the other data should be working
new update ready to try
OK that seems to have worked here is the output of sentwindy.com.txt file “SUCCESS”
Just have to wait a little while to see what happens on Windy
One thing
Make sure you have the time zone set
Correct in the sun/ moon rise / set and
Solar setup
So that the UTC time is correct
looks like its working now
Again thanks very much for all the work that you do, VERY much apreciated
Best Regards
Hi Brian, yes it worked but its not updating automatically. unless I run test a data send every hour nothing happens
here is the output of sendwindycomdata,
“https://stations.windy.com/pws/update/?&winddir=157&ts=1555832400&windspeedmph=0&windgustmph=0&humidity=74&tempf=74.8&rainin=0.000&baromin=30.144&dewptf=66.0&uv=0.0
https://stations.windy.com/pws/update/?&winddir=157&ts=1555832400&windspeedmph=0&windgustmph=0&humidity=74&tempf=74.8&rainin=0.000&baromin=30.144&dewptf=66.0&uv=0.0”
ah
so the automatic running of the cron program is not happening?
You might want to remove your private API key from the first post.
I see the problem, I had used code from the Mac version, and the nameing of the cron program is different to linux
upoading a fix now
Thanks Mark
