Author Topic: What is the status on using WeatherFlow's Solar and UV data?  (Read 415 times)
Offline Weerstation
  • The Netherlands
  • Mozilla compatible
« on: April 13, 2019, 06:01:12 AM »
I am using my VantageVue as primary weatherstation, displaying weatherdata in the saratoga template.
It does not have Solar and UV on board.
For Solar I am using the hobbyboards solar sensor.
No UV available.
I like to use the WeatherFlow's Solar and UV data for my saratoga template. (Brightness and Lightning Strike data will be welcome as well)
Last time I asked, you wrote that it was currently not available.
Can you tell me what the status is right now or will this not be available at all.
Vantage Vue (Firmware 2.14 EU) - WeatherDisplay 10.37S build 98 - USB Weatherlink IP Data Logger
Windows 10 Home 64-bit - HP Pavilion G7 Intel Core I3 2.4 GHz 4 Gb
  • Davis VP2
  • Chrome 73.0.3683.86
    • Weather Display
Re: What is the status on using WeatherFlow's Solar and UV data?
« Reply #1 on: April 13, 2019, 09:38:36 AM »
it could be done, mixing and matching like that, I guess
when I have spare time to implement
Offline Weerstation
  • The Netherlands
« Reply #2 on: April 13, 2019, 09:41:56 AM »
That would be great, thanks.
  • Davis VP2
  • Chrome 73.0.3683.103
    • Weather Display
« Reply #3 on: April 17, 2019, 08:29:55 AM »
try this update
and setup under setup, advanced/misc
Offline Weerstation
  • The Netherlands
« Reply #4 on: April 17, 2019, 05:10:55 PM »
I am getting solar and uv data in current conditions.
Solar data in the saratoga template as well, showing WF data.
I have turned off dallas1wirereader for hobbyboards solar sensor.
Is there something else I have to disable in the solarsensor setup.
Percentagenumber is now being calculated for WF solar data?
Thresholds are now using the WF percentage?
I like to have a space between the last digit and the letter W.
63.0W/m2 to 63.0 W/m2
Can that be fixed.
« Last Edit: April 17, 2019, 05:19:08 PM by Weerstation »
  • Davis VP2
    • Weather Display
« Reply #5 on: April 17, 2019, 06:56:59 PM »
people are never happy
Offline Weerstation
  • The Netherlands
« Reply #6 on: April 18, 2019, 10:46:14 AM »
Just noticed that another tag displays at the same location like in the image.
Saying Solar: 79 W/m2
No UV displayed.
That was the last value from the hobbyboards solarsensor when I updated to the new version supporting WF Solar, I guess.
The UV Steelseries gauge shows 0.0 UV, then WF's value, back to 0.0 UV again, WF's value, 0.0 UV....etc
Also, Cronweatherflow is displaying an Error 143 Busy performing current action at time....
Upperleftcorner beneath ok, ok, ok
Percentage and sunhours do not change, maybe related?
« Last Edit: April 18, 2019, 04:55:37 PM by Weerstation »
Offline Weerstation
  • The Netherlands
« Reply #7 on: April 21, 2019, 10:13:43 AM »
Got the percentage and sunshinehours working now.
Unchecking "Use this value" in the 1Wire Solar setup did the trick.
Still got two tags toggling in the current conditions of wd at the same position.
One only saying solar, the second solar and uv.
Solarvalues are now both the same and reflect the actual WF solar value.
Tags toggle on and off.
I suspect the one only showing solar sets the UV value at 0
Testtags.php shows true values and the value 0, on and off.
I did not add that tag to the current condition screen myself.
Do you know perhaps where this tag, only showing solar is coming from?
In Station type and settings at davis.
Do I have to check "I have Solar and UV" at davis vp/vue settings?
« Last Edit: April 21, 2019, 10:19:27 AM by Weerstation »
Offline Weerstation
  • The Netherlands
« Reply #8 on: April 30, 2019, 06:01:45 PM »
From my 42019vantagelog.txt
UV values become 0.0 (column 7)
Any idea what's happening here.
30  4 2019 17 37 170.00 1.2 0.0 255.0 100.000
30  4 2019 17 38 172.00 1.2 0.0 255.0 100.000
30  4 2019 17 39 171.00 1.2 0.0 255.0 100.000
30  4 2019 17 40 169.00 1.2 0.0 255.0 100.000
30  4 2019 17 41 166.00 1.2 0.0 255.0 100.000
30  4 2019 17 42 159.00 1.1 0.0 255.0 100.000
30  4 2019 17 43 151.00 0.0 0.0 255.0 100.000
30  4 2019 17 44 144.00 0.0 0.0 255.0 100.000
30  4 2019 17 45 137.00 0.0 0.0 255.0 100.000
30  4 2019 17 46 130.00 0.9 0.0 255.0 100.000
30  4 2019 17 47 122.00 0.8 0.0 255.0 100.000
30  4 2019 17 48 115.00 0.0 0.0 255.0 100.000
30  4 2019 17 49 110.00 0.8 0.0 255.0 100.000
30  4 2019 17 50 110.00 0.8 0.0 255.0 100.000
30  4 2019 17 51 111.00 0.0 0.0 255.0 100.000
30  4 2019 17 52 113.00 0.8 0.0 255.0 100.000
30  4 2019 17 53 113.00 0.0 0.0 255.0 100.000
30  4 2019 17 54 113.00 0.0 0.0 255.0 100.000
30  4 2019 17 55 115.00 0.8 0.0 255.0 100.000
30  4 2019 17 56 116.00 0.0 0.0 255.0 100.000
30  4 2019 17 57 115.00 0.8 0.0 255.0 100.000
30  4 2019 17 58 111.00 0.0 0.0 255.0 100.000
30  4 2019 17 59 109.00 0.8 0.0 255.0 100.000
30  4 2019 18  0 109.00 0.8 0.0 255.0 100.000
30  4 2019 18  1 111.00 0.8 0.0 255.0 100.000
30  4 2019 18  2 110.00 0.8 0.0 255.0 100.000
30  4 2019 18  3 110.00 0.0 0.0 255.0 100.000
30  4 2019 18  4 114.00 0.0 0.0 255.0 100.000
30  4 2019 18  5 121.00 0.0 0.0 255.0 100.000
30  4 2019 18  6 129.00 0.9 0.0 255.0 100.000
30  4 2019 18  7 138.00 1.0 0.0 255.0 100.000
30  4 2019 18  8 138.00 1.0 0.0 255.0 100.000
30  4 2019 18  9 139.00 1.0 0.0 255.0 100.000
30  4 2019 18 10 141.00 0.0 0.0 255.0 100.000
30  4 2019 18 11 143.00 0.0 0.0 255.0 100.000
30  4 2019 18 12 146.00 1.0 0.0 255.0 100.000
30  4 2019 18 13 147.00 0.0 0.0 255.0 100.000
30  4 2019 18 14 143.00 1.0 0.0 255.0 100.000
30  4 2019 18 15 135.00 1.0 0.0 255.0 100.000
30  4 2019 18 16 128.00 0.9 0.0 255.0 100.000
30  4 2019 18 17 118.00 0.0 0.0 255.0 100.000
30  4 2019 18 18 118.00 0.8 0.0 255.0 100.000
30  4 2019 18 19 119.00 0.8 0.0 255.0 100.000
30  4 2019 18 20 123.00 0.9 0.0 255.0 100.000
