Recently, WD is not displaying my solar or uv readings. I’ve checked all my settings and all seems fine. WeatherLink and Cumulus are displaying my solar and uv data. Did I miss a setting somewhere?
what weather station type?
Hi Brian: It’s a VP2 to which I added the solar and uv sensors some years ago. WD had been displaying the readings up to now.
what version/build of WD?
solar and UV is showing on my WU new style web page now I see
one thing
make sure you have the switch on in the solar setup in WD (control panel, solar setup)
WD version 10.37S93 and the switch is on, thanks Brian.
you can see what data is sent to WU in the sentwudata.txt file
do you see solar data there?
also does the solar data show in WD, eg above the windspeed dial etc?
There is no solar or uv data being sent to WU and no display in WD above the wind dial. It’s unusual as my data is displaying in my other weather programs.
do you have set in the weather station type, Davis setup, that you have solar +uv?
Yes. I’ve been using WD a very long time and the settings have been the same. I did just go over all the settings again just to make sure
the best thing is email me your settings files and I will check/test here
(there is a FAQ on how to do that)
Will do, Brian, thanks very much.
have not seen the email with your settings yet?
all you need to do is go action, back up windows registry settings, in WD
and email me the file databackup42019.zip that is created
from the WD databackup folder
Email sent, thanks, Brian.
I found the in correct settings in your settings and have emailed you
You’ve been a great help, thanks very much, Brian
