Brian
Here is an example of the “art of possible”. Using node-red to subscribe to the message and generate a dashboard.
Renato
Brian
Renato
kewl
I thought there might be a way to drive a live web site , yes?
so no ftp need to get your data there
Brian
I guess node-red could be used for creating a more detailed webpage. That would indeed eliminate the need for ftp/sftp.
I planning to reach out to one of my colleague at work tomorrow who is the “expert” on node-red.
Meanwhile, if you wish to play with it, you can install NR on a footprint as small as a RPi.
[{"id":"e959a54f.7adff8","type":"ui_gauge","z":"3184c35f.9c6f6c","name":"","group":"d702a2bb.6772d","order":5,"width":"8","height":"8","gtype":"gage","title":"Outside Hum","label":"%","format":"{{value}} %","min":0,"max":"100","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1101,"y":514,"wires":[]},{"id":"d702a2bb.6772d","type":"ui_group","z":"","name":"Weather Display - Southampton","tab":"eb9cf7e0.fcf888","order":1,"disp":true,"width":"28","collapse":false},{"id":"eb9cf7e0.fcf888","type":"ui_tab","name":"Tab 1","icon":"dashboard","order":1}]
One more question/asl, not trying to be a pig
How difficult would it be to give the option to publish either clientraw or customclientraw.txt. The latter already being in JSON format would lend itself better for loading the data into a database, specifically InfluxDB.
Renato
yup, i can add option to send customclientraw instead
i have added that option now to the latest .zip update (normal download)
Brian
tried the new version…
The option to send customclientraw does not appear to stick. Had to try different combinations between checking and un-checking clientraw and customclientraw to finally have customclientraw and clientraw both stick.
The published message still looks like this:
Southampton01!12345 4.4 2.6 296 7.2 59 1013.0 2.3 24.6 267.7 0.00 0.00 19.8 51 100.0 1 0.0 0 0 0.3 -54.4 255.0 -65.0 -67.8 -100.0 -100.0 -100 -100 -100 23 43 38 N3KJE-11:43:38_PM 0 0 15 4 0.00 0.00 100 100 100 100 100 5.7 5.0 21.1 7.2 1 Night_time/Dry/Clear_skies 0.7 3 3 3 3 3 6 6 4 3 4 4 3 2 2 3 7 4 3 3 3 17.4 -0.3 3085.0 4/15/2019 27.7 5.0 21.1 4.4 0.0 3 4 4 3 5 1 3 3 1 3 7.8 7.7 7.7 7.7 7.6 7.4 7.4 7.4 7.4 7.2 2.3 2.3 2.3 2.3 2.3 2.3 2.3 2.3 2.3 2.3 21.1 7.2 7.2 11.0 0 — — 297 0 0 -100.0 -100.0 0 -100 -100 -100 -100 0.0 23.8 19.7 4.5 1013.0 992.5 11 11:24_PM 2:59_PM 23.5 3.1 18.9 -0.5 9 2019 0.0 -1 1 -1 297 252 287 290 278 286 300 288 19 296 0.0 255.0 2.4 4.3 40.18528 75.02556 1.3 92 52 2.3 11:35_PM 0.0 0.0 0.0 0.0 0.0 0.0 109.8 2:00_AM 11:42_PM 299 !!C10.37S94!!
i.e. without the field names as opposed to the one WD if FTP’ing which looks like this:
{“date”:“11:48 PM”,“dateFormat”:“m/d/y”,“temp”:“45.0”,“tempTL”:“45.0”,“tempTH”:“70.0”,“intemp”:“67.7”,“dew”:“31.5”,“dewpointTL”:“31.1”,“dewpointTH”:“66.0”,“apptemp”:“41.2”,“apptempTL”:“37.4”,“apptempTH”:“74.3”,“wchill”:“43.9”,“wchillTL”:“39.7”,“heatindex”:“45.0”,“heatindexTH”:“70.0”,“humidex”:“5.0”,“wlatest”:“3.0”,“wspeed”:“3.1”,“wgust”:“10.3”,“wgustTM”:“20.0”,“bearing”:“299”,“avgbearing”:“303”,“press”:“29.916”,“pressTL”:“29.308”,“pressTH”:“29.916”,“pressL”:“28.756”,“pressH”:“30.838”,“rfall”:“0.09”,“rrate”:“0.000”,“rrateTM”:“0.000”,“hum”:“59”,“humTL”:“52”,“humTH”:“92”,“inhum”:“52”,“SensorContactLost”:“0”,“forecast”:“partly cloudy and cooler.”,“tempunit”:“F”,“windunit”:“mph”,“pressunit”:“inHg”,“rainunit”:“in”,“temptrend”:“-1.1”,“TtempTL”:“11:42 PM”,“TtempTH”:“2:00 AM”,“TdewpointTL”:“11:44 PM”,“TdewpointTH”:“3:29 AM”,“TapptempTL”:“11:44 PM”,“TapptempTH”:“2:48 AM”,“TwchillTL”:“2:00 AM”,“TheatindexTH”:“2:00 AM”,“TrrateTM”:“2:30 PM”,“ThourlyrainTH”:“”,“LastRainTipISO”:“4/15/2019 10:34 PM”,“hourlyrainTH”:“0.000”,“ThumTL”:“2:30 PM”,“ThumTH”:“5:08 AM”,“TpressTL”:“3:31 AM”,“TpressTH”:“11:46 PM”,“presstrendval”:"+0.095 ",“Tbeaufort”:“5”,“TwgustTM”:“2:59 PM”,“windTM”:“12.7”,“bearingTM”:“298”,“timeUTC”:“2019,04,16,03,48,26”,“BearingRangeFrom10”:“274”,“BearingRangeTo10”:“19”,“UV”:“0.0”,“UVTH”:“5.1”,“SolarRad”:“0”,“CurrentSolarMax”:“0”,“SolarTM”:“984”,“domwinddir”:“West northwesterly”,“WindRoseData”:[7.0,8.0,3.0,0.0,0.0,0.0,0.0,0.0,0.0,2.0,6.0,9.0,97.0,955.0,181.0,38.0],“windrun”:“68.58”,“version”:“10.37S”,“build”:“94”,“ver”:“10”}
Renato
I’m trying to get a similar dash to Renato’s - I’ve now got Node-RED running fine on my Synology server and I’ve started adding the elements per his dashboard - however I don’t know what to actually enter in each of the split and route boxes etc. Maybe I need to do some reading (a lot) but if Renato could do a quick-start post it would be very much appreciated … Thanks in advance
VK2HIM
Salutations from N3KJE
Go to the ND page. It should be accessible from http://IP_ADDRESS:1880
On the “Hamburger icon” (4 horizontal lines on the top right of the screen) click the option Import → Clipboard
In the “Paste nodes here” block, paste the following code:
[{"id":"3184c35f.9c6f6c","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"bea7e640.b05dd8","type":"mqtt in","z":"3184c35f.9c6f6c","name":"","topic":"Southampton/WD/","qos":"2","broker":"7a840a3e.085984","x":268,"y":109,"wires":[["f7b827d2.c06358"]]},{"id":"f7b827d2.c06358","type":"split","z":"3184c35f.9c6f6c","name":"","splt":" ","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":494,"y":131,"wires":[["de3d28a6.46d508"]]},{"id":"de3d28a6.46d508","type":"switch","z":"3184c35f.9c6f6c","name":"route","property":"parts.index","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"2","vt":"num"},{"t":"eq","v":"3","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"5","vt":"num"}],"checkall":"true","repair":false,"outputs":5,"x":689,"y":539,"wires":[["ac7b2495.072268"],["f67efdc1.922c9"],["3edabef.cfd1642"],["dc4caa53.e2c0b8","1d404512.0be63b"],["e959a54f.7adff8"]]},{"id":"ac7b2495.072268","type":"ui_gauge","z":"3184c35f.9c6f6c","name":"","group":"d702a2bb.6772d","order":1,"width":"0","height":"0","gtype":"gage","title":"Average Wind Speed","label":"Knots","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1132.5,"y":133,"wires":[]},{"id":"f67efdc1.922c9","type":"ui_gauge","z":"3184c35f.9c6f6c","name":"","group":"d702a2bb.6772d","order":2,"width":"0","height":"0","gtype":"gage","title":"Wind Gust","label":"Knots","format":"{{value}}","min":0,"max":"50","colors":["#00b500","#e6e600","#ca3838"],"seg1":"","seg2":"","x":1105,"y":232,"wires":[]},{"id":"3edabef.cfd1642","type":"ui_gauge","z":"3184c35f.9c6f6c","name":"Degrees","group":"d702a2bb.6772d","order":3,"width":"0","height":"0","gtype":"compass","title":"Wind Direction","label":"Degrees","format":"{{value}}
my bad
try again a new .zip update
the new setting was only being saved if you clicked on test send
Brian
I am still not seeing the field names as part of the message. Just the values (and not a key/value combo).
Renato
Thanks Renato - good to see a fellow ham!!
I’ll follow these instructions when I’m home from work and report back - cheers!
Hi Renato,
I’m having trouble configuring WD for mqtt - I’m not sure if I’ve configured it correctly or I’ve got Node-Red wrong?
Server - I’m using the IP address of the PC that’s running WD - is that correct? 192.168.1.75
Port 1883
Client ID I left blank but I tried 99 with no luck
QoS - At most once
Topic is Gerringong/WD/
blank username password
update rate 60 or 10 made no difference
When cron WD MQTT ver 1.6 starts - opening teh windo shows blank in Received and Status and Message to send says:
This action requires a connected state (C:\Users\Brian\Documents\tmssoftware\TMS MQTT\TMS.MQTT.Client.pas, line 518)
I configured Node-Red using your script and matched the same settings for Topic - QOS 0 - Server 192.168.1.75 and port 1883 - blamk Client ID and user/password blank.
After deploying and restarting flows it says connecting with nothing else.
Any clues? Thanks
Brian
Yes, now it works.
Thanks again
Renato
vk2him
First I would download mqtt-spy. This utility allows you to connect to the mqtt server and validate that mosquitto is properly configured and up and running.
You can find it here https://github.com/eclipse/paho.mqtt-spy/wiki/Downloads
Once started go to Connections → Manage connections to create a new one for your environment. With a new connection created, click on “Control Panel”. You should now see a button for your server appear in the middle section. Click on it. If it turns green then it means that your mqtt server is up and running.
Next check your WD setting:
I am attaching a screenshot of my setup. Please noe:
Let me know if this works for you.
Thanks for the help Renato - I think I see my problem. I’m assuming your ip address 192.168.1.50 you have setup in WD is your mqtt server?
I didn’t realise I needed a mqtt server - I have a Solar/Power meter that directly outputs mqtt and I’ve been able to connect and receive data using Node-Red running on my Synology directly connected to the solar meter without needing a mqtt server. I (wrongly) assumed WD was also able to also directly connect without a mqtt server.
So now I’ll investigate mqtt servers - it may be better to run the mqqt server on my Synology than on the Windows10 laptop that WD is currently running.
I’ll try again tonight
Regards
Ian
Ian
If this is an option for you, I would probably invest in a Raspberry Pi 3B+ and deploy Mosquitto there. Later on, you may also want to install there MySQL/MariaDB etc.
Personally I like to “leave the NAS” alone.
My 2c
Renato
Thanks Renato - I have mariaDb and mysql working successfully on my Synology - it gathers data from my Blitzortung lightning detector:
http://www.theshackbythebeach.com:443/mybo/index.php?bo_page=map
I’ll investigate teh options tonight - thansk for the suggestions - cheers
Hi Renato - It’s taken me a few days to do testing etc
Partial success - long story short - for unknown reasons running Node-red on my Synology won’t allow me to connect to the Mqtt broker thats also running on the Synology. WD is able to publish to the broker fine and I can subscribe to the broker using a test mqtt.fx app. I can connect from Node-red on the synology to another mqtt device on a different IP and it works fine, I even created some new gauges to display the other mqtt data. I then tried installing Node-red on my windows laptop and I could connect to the Synology broker and display the WD gauges.
So something is broken on the Synology that doesn’t allow Node-red to connect - I tried localhost and 127.0.0.1 as well as the IP of the Synology without luck. I even tried a different Node-red docker container and it had the same problem.
I’ll keep checking … thanks anyway
