Any suggestions on where to look for the problem? I created the ini files and gave them 777 permissions as well as their parent directory but nothing helped…
Also, WD is getting info from someplace as the data counter is incrementing. I thought I turned off all internet access and metar data so what WD is counting is unknown. Do you have removal instructions for the IOS version of WD? I’ve tried deleteing WD but everytime I re-install it WD is finding settings from earlier installs and I have no idea where these settings are stored.
Another question…I do not have the Weatherflow USB connected to my iMac. WD appears to be able to access WF via wifi since WD finds the sensors ok when I hit the button to find sensor names. Does WD require the WF to be physcially connected to the computer running WD?
