cronweatherflow is showing no data…station is online according to the app…see Tempest
10.37Mac311 version in use…not sure what to select for comm port with this station…
you have not set a station ID
e.g 6695
yes
in the weather station type setup in WD, where you select the weather flow station type
(do that when the cronweatherflow program is not running…then start that up or restart WD)
The iMac is not picking it up for some reason. See the attached in my previous message. cronweatherflow will not pick up the station ID.
FWIW, I tried it on my Win10 machine and it worked just fine so something about the IOS version…
are you sure you followed my instructions carefully?
Yes, I quit cronweatherflow, re-entered the ID#, then hit enable. cronweatherflow starts up with no ID#.
Maybe a clue…when starting up WD it shows as attached. cronweatherflow does start, but I closed it before taking this snap of the screen. WD title bar says weatherflow, but it still seems to be defaulting to davis. It’s been a long time since I messed with IOS version of WD and I can’t remember if there is an ini file or where WD stores this info…is it possible to manually edit the ini file in IOS?
Looks like a permision error
With that settings file in that error
Any suggestions on where to look for the problem? I created the ini files and gave them 777 permissions as well as their parent directory but nothing helped…
Also, WD is getting info from someplace as the data counter is incrementing. I thought I turned off all internet access and metar data so what WD is counting is unknown. Do you have removal instructions for the IOS version of WD? I’ve tried deleteing WD but everytime I re-install it WD is finding settings from earlier installs and I have no idea where these settings are stored.
Another question…I do not have the Weatherflow USB connected to my iMac. WD appears to be able to access WF via wifi since WD finds the sensors ok when I hit the button to find sensor names. Does WD require the WF to be physcially connected to the computer running WD?
Ok, figured it out. Once I removed WD completely and re-installed it now reads the Weatherflow data. Have some issues with graphing solar and can’t find the lightning settings to verify, and the “rain today” is not showing correct on the WD console. Sucks they couldn’t see their way to include and indoor thermometer with this station but I can live without that…
Re solar
Make sure the switch is on in the solar setup
Re lightning
Try the latest update
I am away this weekend at a university reunion
But will test the solar and lightning when I get back
Oh and you can have indoor temp/ hum
Via a second air sensor
And then you set that sensor to be used for
Indoor in WD
Ok, if you want we can work on this when you return. FYI, downloaded latest, not seeing solar or uv plotted on WD console. Solar is being picked up by WD and the solar% shows on the console above the graph but no plot. I set to store the UV as extra hun #4 but I do not see uv anywhere on the console screen. As for lightning, it’s a rare event here but the NWS says we may get some this evening…if WF picks up some strikes I will let you know if it’s graphed or not. (add: strikes recorded by WF do not show on WD console)
How do I get those vertical lines that keep showing up on the graphs that move with the cursor if I mouse over the graph? They keep popping up on the graphs even when I don’t mouse over the WD console…
And what are the two bars above the compass? (add: They appear to show solar% on the top bar and maybe hours of sun on lower bar?)
(add: Could you reduce the WD console Rain Today to only show 2 decimal places? Mine is showing 4 decimal places for some reason.)
the rain shows that number of decimal places because it can (i.e because the WF rain sensor reports to a lot of decimal places)
yes
How do I get those vertical lines that keep showing up on the graphs that move with the cursor if I mouse over the graph? They keep popping up on the graphs even when I don't mouse over the WD console...its just a graphics glitch on the mac/linux version. only solution is I can look to see to not show the vertical line at mouse cursor position
re lightning, did the strike show under view, lightning strikes?
i will so some testing here today
