WD uses the pc time/date . not the stations
logfiles are text based, so you can edit (and then convert to the data files)
datafiles are for the graphs
you can set to have WD restart daily, see under control panel, ftp/internet setup, reboot
and yes WD can be set to catch up on history data (see in the data logger setup) if your station hardware has that ability/compatible
