WD does not have the lock up problem with the WH1081/WH3081 type stations
only WU, the others do not provide a ready available way to get your data
Thanks once again Brian… last question
Will WD support this Fine Offset
http://www.ecowitt.com/weather_station/5.html
HP3500B
Yes
As already stated
Via WU Data ( using the new api)
If the station is set to send to that
Note that the HP3500B has a tiny (but nice) console display.
Hi Bran
Also has a USB connection to a PC. which is what I was thinking about?
tc
I do not know how or if that can even be used
but it might work like this model
http://kona2.alc.upv.es/Estacio_Meteorologica/aercusWDsetup.htm
The HP3500B don 't Works with this method
can that station be set to send data to WU?
Yes they work with WU, but WU is slow and not very reliable
its just that , that is one way to get data, via WU, into WD (but yeah limited on the update rate)
thanks for the info. Can WD get the data from an IP connected Fine Offset weather station? Such as the WH2320E - they are all using the same outside unit, but subtle differences in the console. The WH2320E can publish direct to the internet (wireless) and can be connected to a PC via IP.
tc
I am not sure of the IP data protocol for that new station type
(seems that every model they change the data protocol)
it might be similar to the standard WiFi pro station
i.e that works like this
or it might not
Se
so the pc software that comes with it can get the data via the usb connection
I wonder if the data protocol is the same then
and I see then that software is not tied strictly to WU , i.e you can set the destination for that HTTP GET data
and so have a script to read that data
that could then be a way to get WD to catch that data too via setting to a local IP address ?
I have tried to catch the data via HTTP and USB and no luck
are you able to set the destination IP address for the WU type data in the software?
I am a little confused about what WD will support
The HP3500B has a USB interface which talks to EasyWeather 2 or Plus. My understanding is WD can talk to FineOffset USB interefaces… but apparently not this one?
WD can be set to use the easy weather history.dat file
if that file is still produced by the latest easy weather software version and its the same format, then that is one way
I have sent an email to ecowitt to see if there is any api to get the weather data from their server
they got back to me
the api is not available for a long time
although they have made it available to meteobridge
