Author Topic: Updating to latest version  (Read 335 times)
Offline youngros
  • Madeira, Portugal
  • Win NT 10.0
  • Chrome 73.0.3683.86
    • Madeira Weather
« on: March 24, 2019, 12:19:08 PM »
Several things over the years have thwarted my updating to the latest version. I am "still" running 10.37R b81  :oops:  But it works.
Anyway now that things seem to have settled down, I have moved to a new server, still running php 5.6 but now need to look at getting everything ready to run on php 7.
I have everything backed up and still have a copy of the b81 download should things try and go pear shaped on me.
Is there anything I should watch out for when doing this? I am running Windows10.
Rosalind
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
    • Traveling RV Weather
Re: Updating to latest version
« Reply #1 on: March 24, 2019, 06:13:30 PM »
Only thing I can think of is the WD executable name changed at some point so if build 81 is using the old name your link will need to be changed for starting WD.  Other than that, all the new stuff added to WD will need to be configured at some point.  If you run into trouble just holler and someone here should be able to help.
Offline youngros
  • Madeira, Portugal
  • Win NT 10.0
    • Madeira Weather
« Reply #2 on: March 24, 2019, 07:06:30 PM »
Thanks for that.
My startup icon says C:\wdisplay\WeatherD.exe and the target is wdisplay  Can I manually change this to C:\wdisplay\weatherdisplay.exe after doing the update? Will it still work on auto start up, or is there some editing to be done there?
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
« Reply #3 on: March 24, 2019, 10:29:24 PM »
Yes you can edit the short cut if needed.  It's been so long, but I seem to recall either I installed WD to a new directory, or perhaps the installer will select a new directory for you when you run the install.  If that happens, just make sure you run the correct WD  :wink:
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #4 on: March 24, 2019, 10:39:32 PM »
In W10 you may need to change to starting WD with task scheduler to have it run automatically with admin privileges.
Offline youngros
  • Madeira, Portugal
  • Win NT 10.0
    • Madeira Weather
« Reply #5 on: March 25, 2019, 11:35:30 AM »
Done!
The only thing that I noticed was that when WD started the logger download didn't do anything, it just hung so I aborted that and the data loaded. There is only 10 minutes missing, which is nothing, it isn't raining yet! Normally that just flashes up and then disappears. Until I start it up again I won't know if this will happen again.
Other than that I haven't noticed anything else not working yet. I have changed the shortcut to WeatherDisplay.exe and also edited the Task Scheduler to the same.
So far so good.
If only I could fix my graphs as quickly  :(
Rosalind
