Hello
Im planning to run WD on a small PC as weather center (sort of) and I would like to have all the sensors displayed.
A screenshot with the available sensors is attached.
If someone can and have the time to tell me how I should define those sensors in WD it will be great and really welcomed.
Thank you
Emil
I am not sure what you are asking
WD can be set to get data from MeteoHub
what is not working?
IT IS working but I would love to have the same sensor descriptions also on PC (Weather Display) like defined on meteohub. It would make my life easier to check the values…
I never said that is not working ans sorry if my question was not correctly formulated or incomplete…
Thanks for your reply
Emil
it is still not clear to me what you are needing?
I think Emil may be wanting to label the sensors as on the screenshot, e.g. Phillip, Greenhouse etc.
label them where?
in WD?
if so, where exactly?
you can label them with custom tags on the main screen
Hello
hmm, I wasn’t thinking that my English is really that bad, English is not my native language so it can be that the formulation that I use is a little bit , let’s call it, unusual so, please excuse my mistakes.
YES I want the same labelling but the point is that I don’t know how should I do it… that’s why I ask here because I don’t know something not because I have nothing better to do.
Thank you again for your time
Emil
You can set a custom tag on the main
Screen
To show extra sensor data
And you can then use another custom
Tag to then be a label to name that sensor
There are you tube videos, with one showing
Main screen customisation
