Well, this is a bit of a weird one and I can’t figure out how to fix it…
I recently switched from a Davis Vantage Pro to a Weatherflow and I still use lots of 1-wire extra temp sensors.
I haven’t looked carefully at my extra sensor graph for a few months and I just noticed that Extra Temp Sensor #7 is showing mV and a totally different scale on the Extra Sensors Realtime Graph. It looks like it might be reporting the temperature value (it’s showing 23.3mV but the sensor is actually reading 23.4C when I probe it with OneWire Viewer or look at the WD Dallas 1-wire viewer), but it has assigned it a unit value of mV instead of Celsius. Also the scale is from 0 to 250.
I’ve gone into Extra Sensors Graph>Setup and tried changing the range and clicking the ‘Set’ button as per normal, but that doesn’t seem to have any effect. Normally I have Customise Data to Plot enabled. I have tried turning that off and it seems to bring the units back to Celsius from mV, but the graph scale is still 0 to 250.
I’m really flummoxed.
I checked to make sure that there is not a solar sensor mapped to Extra #7, but I never used a 1-wire solar sensor and I’m just not sure why this is happening now or how to fix it?
EDIT: I just found an older post on the forums here where someone had the exact same problem with Extra Sensor #7, but it looks like there was not posted resolution/solution for them http://discourse.weather-watch.com/p/486282
