Author Topic: No Humidity Sensor - Davis Vue  (Read 183 times)
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
  • Chrome 72.0.3626.121
    • Traveling RV Weather
« on: March 10, 2019, 07:13:11 PM »
The humidity sensor died on my Davis Vue.  I am undecided if I want to replace the Vue with a VP2 but in the mean time...is there a way to tell WD to ignore the sensor?  The problem is the datalogger still collects bad readings from the Vue and WD imports these bogus readings and in turn graphs them...and that affects dewpoint...and...well you get the idea.  I have to edit the logfile to remove the bad readings then convert the log to clean things up.  So is there a way to get WD to ignore the humidity readings?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: No Humidity Sensor - Davis Vue
« Reply #1 on: March 10, 2019, 07:29:29 PM »
you can set WD to use the humidity from a metar
and or you can set a humidity offset
and or you could replace the sensor?
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #2 on: March 10, 2019, 08:14:00 PM »
Depending on the revision of the Vue it may not be possible to replace just the RH sensor.
How about getting just a VP2 ISS and continuing to use the Vue console?
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
« Reply #3 on: March 11, 2019, 02:28:37 AM »
I already set to use the metar humidity...but when offline the datalogger continues to read the bad humidity sensor and then WD dutifully imports that data upon restarting  #-o
Yep, this is the 2nd time the sensor has failed, so I won't be buying another Vue.  If I do anything I would buy the VP2 without the console and use my Vue console.  But right now I am leaning towards just leaving it as is, continue to use the metar, and when other sensors quit I will get out of the wx watching hobby.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #4 on: March 11, 2019, 02:37:13 AM »
nothing can be easily done sorry about the offline problem
Offline NorCal Dan
  • Dan - KJ6RGX
  • Davis Vue/Win10
  • Ocean Park, WA.
  • Mac OS X 10.10.5
« Reply #5 on: March 11, 2019, 02:39:50 AM »
Ok, thanks.
