Author Topic: blocking ftp  (Read 325 times)
Offline stonefox
  • Viborg, Denmark
  • Win NT 10.0
  • Firefox 65.0
    • www.Houlkær Viborg
blocking ftp
« on: March 10, 2019, 04:06:02 AM »
Hi - All the files in "Webfiles" folder is updated, but the files don't be uploadet to the server.
How can I test what is wrong or bloking for the upload's ?
I have true to turn off firewall and virus software, but it's don't help.
The Alarm diode is green is it because there is something wrong ?
Can I read in one of the logfiles what the problem is, and if "Yes" with one of them ?
« Last Edit: March 10, 2019, 04:09:21 AM by stonefox »
  • Davis VP2
  • New Zealand
  • Android 7.1.1
  • Chrome 72.0.3626.121
    • Weather Display
Re: blocking ftp
« Reply #1 on: March 10, 2019, 06:29:18 AM »
What shows in the file
ftplogfull.txt
Offline stonefox
  • Viborg, Denmark
  • Win NT 10.0
  • Firefox 65.0
Re: blocking ftp
« Reply #2 on: March 10, 2019, 08:04:05 AM »
There isn't no file with then name. How can I enable it ?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: blocking ftp
« Reply #3 on: March 10, 2019, 08:26:20 AM »
make sure you have set to log the FTP in the connections setup in WD
also make sure your antivirus program has not deleted the ftpupd.exe program
if it has then re install WD (full install)
Offline stonefox
  • Viborg, Denmark
  • Win NT 10.0
  • Firefox 65.0
Re: blocking ftp
« Reply #4 on: March 10, 2019, 11:52:10 AM »
Here is the log text.
But what is the problem ?
Filename: ftplogfull.txt
*******list of files uploaded********
Uploading C:\wdisplay\webfiles\clientraw.txt -> clientraw.txt
Uploading C:\wdisplay\webfiles\clientrawtemp.txt -> clientrawtemp.txt
Uploading C:\wdisplay\webfiles\clientrawhour.txt -> clientrawhour.txt
Uploading C:\wdisplay\webfiles\Ventus.html -> Ventus.html
Uploading C:\wdisplay\webfiles\datahtm1.txt -> datahtm1.txt
Uploading C:\wdisplay\webfiles\customclientraw.txt -> customclientraw.txt
*******actual messages from upload session********
***Start Time/date***:12:45:29 10-03-2019
Permanent connection selected
Checking for what else to do...
there are 1 more things to do
Starting FTP transfer Now to 2nd server
Logging onto :94.231.103.100
Logging onto FTP server....94.231.103.100
Connecting to FTP server.
[10060] Connection timed out
Failed to connect: [10060] Connection timed out
FTP error occured
FTP error, looking for next agenda item
Checking for next FTP agenda....
there are 2 more things to do
Doing ftp upload
143: Busy performing current action.
Checking there are files to upload
There are more files to upload
No more files to upload
All Agenda complete, doing FTP log off....
FTP logoff
Doing abort procedure/program close...
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
Re: blocking ftp
« Reply #5 on: March 10, 2019, 01:17:39 PM »
Quote
There is no FTP server responding at IP addresss 94.231.103.100
Offline stonefox
  • Viborg, Denmark
  • Win NT 10.0
  • Firefox 65.0
Re: blocking ftp
« Reply #6 on: March 10, 2019, 10:19:52 PM »
please test now.
There in Weather display can I Test mt ftp settings  and get a messages "connection OK" og "Connection Failed" ??
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
Re: blocking ftp
« Reply #7 on: March 10, 2019, 11:12:20 PM »
From my PC I can ping 94.231.103.100 and get a response so I have a connection, but there is no response to trying to connect with FTP.
You can see in ftplogfull.txt that you posted above, WD can access the server but there is no response to FTP:
Quote
A simple way to test is from a command prompt in Windows, at the prompt type
ftp 94.231.103.100
and hit Enter
If that was an active FTP server it would ask for a logon, otherwise it will time out.
Offline stonefox
  • Viborg, Denmark
  • Win NT 10.0
  • Firefox 65.0
Re: blocking ftp
« Reply #8 on: March 11, 2019, 09:13:55 AM »
Thanks for your help.
