Website Hosed Up
I don’t know if this is a WD problem, or a website hosting problem. But my website shows incorrect update info, and is not displaying correctly. I contacted Hostmonster,my web hosting site and they claim the problem is at my end… :roll: Sometimes my website will show correctly, but if you refresh the browser, its all hosed up. Here is some info:
OS: windows Vista
WD: version 10.37S90
I’ve made no changes to WD settings, and its been running flawlessly for months… They, Hostmonster claim the problem is at my end, but if I’m correct the FTP data log states different…?
Bob
for some reason you must have set to use this different remote directory
in the customise internet and file creation setup
for some files
check that
also is the remote directory set correctly?
also post here the file
ftplogfull.txt
when the web site is not correct
Wow, thanks Brian I’ll check that out!! Too weird, I haven’t made any changes to WD or directory’s…
Update: I just checked out my website, and refreshed the browser… All is displaying correctly, but the date in the right hand corner… Sigh! #-o
I’ll continue to look Brian
ftplogfull.txt (18.4 KB)
its not clear if that date problem has always been a problem or not?
No it hasn’t… This problem just started on it’s own… I’m seeing errors in the ftplogfull.txt data log that I have attached… somehow I’m seeing a re-directory to CWD public_html…?? should be just public_html… I don’t know. Anyhow, I’ll continue to dig…
Changing to new remote directory for this file
CWD public_html… This is a copy and paste from the ftp datalog
Bob
I dont see any attachment
you do not need to attach
you can just copy/paste the contents
also CWD is not part of the remote directory name
its a FTP command (to change directory)
re the date problem
check the template file for your web site…it might not have any tags in it…it might need replacing with the original etc
Okay shall do… The last time I modified the web template was about 8 months ago… Website has been running just fine up until the last couple of days… I’ll continue to dig tomorrow.
Thanks for your help Brian
Here is the full ftplogfull.txt
list of files uploaded*
Uploading C:\wdisplay\webfiles\index.html → index.html
Uploading C:\wdisplay\webfiles\indexgraph.gif → indexgraph.gif
Uploading C:\wdisplay\webfiles\thumbindexgraph.gif → thumbindexgraph.gif
Uploading C:\wdisplay\webfiles\index.gif → index.gif
Uploading C:\wdisplay\webfiles\indexdial.gif → indexdial.gif
Uploading C:\wdisplay\webfiles\thumbindexdial.gif → thumbindexdial.gif
Uploading C:\wdisplay\webfiles\cloudheight.gif → cloudheight.gif
Uploading C:\wdisplay\webfiles\realtimegraph.gif → realtimegraph.gif
Uploading C:\wdisplay\webfiles\dailyhighlowbaroetc.gif → dailyhighlowbaroetc.gif
Uploading C:\wdisplay\webfiles\trends.gif → trends.gif
Uploading C:\wdisplay\webfiles\thumbtrends.gif → thumbtrends.gif
Uploading C:\wdisplay\webfiles\energy.gif → energy.gif
Uploading C:\wdisplay\webfiles\thumbenergy.gif → thumbenergy.gif
Uploading C:\wdisplay\webfiles\curr24hourgraph.gif → curr24hourgraph.gif
Uploading C:\wdisplay\webfiles\curr48hourgraph.gif → curr48hourgraph.gif
Uploading C:\wdisplay\webfiles\curr72hourgraph.gif → curr72hourgraph.gif
Uploading C:\wdisplay\webfiles\dirplot.gif → dirplot.gif
Uploading C:\wdisplay\webfiles\thumbdirplot.gif → thumbdirplot.gif
Uploading C:\wdisplay\webfiles\dirplotspd.gif → dirplotspd.gif
Uploading C:\wdisplay\webfiles\alltimerecords.gif → alltimerecords.gif
Uploading C:\wdisplay\webfiles\alltimerecordsmonth.gif → alltimerecordsmonth.gif
Uploading C:\wdisplay\webfiles\alltimerecordsyear.gif → alltimerecordsyear.gif
Uploading C:\wdisplay\webfiles\2019alltimerecordsyear.gif →
Uploading C:\wdisplay\webfiles\rainbar3d.gif → rainbar3d.gif
Uploading C:\wdisplay\webfiles\tempchart3d.gif → tempchart3d.gif
Uploading C:\wdisplay\webfiles\piechart3d.gif → piechart3d.gif
Uploading C:\wdisplay\webfiles\datachart3d.gif → datachart3d.gif
Uploading C:\wdisplay\webfiles\dirplot3d.gif → dirplot3d.gif
Uploading C:\wdisplay\webfiles\trend3d.gif → trend3d.gif
Uploading C:\wdisplay\webfiles\trendtempyear.gif → trendtempyear.gif
Uploading C:\wdisplay\webfiles\trendwindyear.gif → trendwindyear.gif
Uploading C:\wdisplay\webfiles\trendrainyear.gif → trendrainyear.gif
Uploading C:\wdisplay\webfiles\gizmo.gif → gizmo.gif
Uploading C:\wdisplay\webfiles\conditionscolour.jpg → conditionscolour.jpg
Uploading C:\wdisplay\webfiles\summary.gif → summary.gif
Uploading C:\wdisplay\webfiles\thumbsummary.gif → thumbsummary.gif
Uploading C:\wdisplay\webfiles\forecasticon.gif → forecasticon.gif
Uploading C:\wdisplay\webfiles\thumbforecasticon.gif → thumbforecasticon.gif
Uploading C:\wdisplay\webfiles\forecasticonmetar.gif → forecasticonmetar.gif
Uploading C:\wdisplay\webfiles\forecasticonstation.gif → forecasticonstation.gif
Uploading C:\wdisplay\webfiles\metar.gif → metar.gif
Uploading C:\wdisplay\webfiles\percentdir.gif → percentdir.gif
Uploading C:\wdisplay\webfiles\thumbpercentdir.gif → thumbpercentdir.gif
Uploading C:\wdisplay\webfiles\clientraw.txt → clientraw.txt
Uploading C:\wdisplay\webfiles\clientrawextra.txt → clientrawextra.txt
Uploading C:\wdisplay\webfiles\clientrawdaily.txt → clientrawdaily.txt
Uploading C:\wdisplay\webfiles\clientrawhour.txt → clientrawhour.txt
Uploading C:\wdisplay\webfiles\moondetail1.gif → moondetail1.gif
Uploading C:\wdisplay\webfiles\moondetail2.gif → moondetail2.gif
Uploading C:\wdisplay\webfiles\forecast5day.gif → forecast5day.gif
Uploading C:\wdisplay\webfiles\climatedataout.html → climatedataout.html
Uploading C:\wdisplay\webfiles\windtempraintrend3.gif → windtempraintrend3.gif
Uploading C:\wdisplay\webfiles\windtempraintrend.gif → windtempraintrend.gif
Uploading C:\wdisplay\webfiles\windtempraintrend3d3.gif → windtempraintrend3d3.gif
Uploading C:\wdisplay\webfiles\windtempraintrend3d.gif → windtempraintrend3d.gif
Uploading C:\wdisplay\webfiles\sunmoonimage.jpg → sunmoonimage.jpg
c:\wdisplay\downloads\orz006.txt
actual messages from upload session*
Start Time/date:6:00:45 PM 3/8/2019
orz006.txt
Permanent connection selected
Permanent connection, will do ftp now
Checking for what else to do…
there are 3 more things to do
Downloading Precipitation Products - Office of Satellite and Product Operations
To local file C:\wdisplay\downloads\20.jpg
Download complete
error during handshake[2]: 0x80090326
Download complete
276: error during handshake[2]: 0x80090326
there are 2 more things to do
Downloading http://www.ssd.noaa.gov/goes/west/nw/wv.jpg
To local file C:\wdisplay\downloads\wv.jpg
Download complete
Download complete
there are 1 more things to do
Finshed email agenda
Finshed email agenda, and more Internet agenda items to do…
Weather Display FTP/Internet vers 9.06
Time/date:6:00:48 PM 3/8/2019
Logging onto FTP server…bobsvp2wd.net
Connecting to FTP server.
OK
Connected.
220---------- Welcome to Pure-FTPd [privsep] [TLS] ----------
220-You are user number 2 of 1000 allowed.
220-Local time is now 19:00. Server port: 21.
220-This is a private system - No anonymous login
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
USER=****
331 User bobsvptw OK. Password required
PASSWORD=****
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Change to remote Dir public_html
CWD public_html
250 OK. Current directory is /public_html
Checking for next FTP agenda…
Doing ftp upload
Checking there are files to upload
There are more files to upload
PASV
227 Entering Passive Mode (74,220,207,119,179,37)
STOR index.html
150 Accepted data connection
226-File successfully transferred
226 0.242 seconds (measured here), 81.33 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,171,152)
226 0.587 seconds (measured here), 94.09 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,171,102)
226 0.002 seconds (measured here), 6.32 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,181,244)
226 5.288 seconds (measured here), 101.38 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,163,84)
226 0.983 seconds (measured here), 97.18 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,168,25)
226 0.002 seconds (measured here), 5.87 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,193,208)
226 0.107 seconds (measured here), 67.99 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,176,184)
226 0.509 seconds (measured here), 89.73 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,188,252)
226 0.243 seconds (measured here), 83.75 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,159,168)
226 0.232 seconds (measured here), 58.13 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,166,233)
226 0.004 seconds (measured here), 3.64 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,181,39)
226 0.231 seconds (measured here), 85.94 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,174,5)
226 0.002 seconds (measured here), 5.88 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,193,167)
226 0.619 seconds (measured here), 88.03 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,187,152)
226 0.589 seconds (measured here), 94.02 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,161,205)
226 0.640 seconds (measured here), 96.43 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,189,31)
226 0.176 seconds (measured here), 76.65 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,194,64)
226 0.002 seconds (measured here), 6.39 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,167,170)
226 0.185 seconds (measured here), 71.40 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,174,167)
226 0.280 seconds (measured here), 82.27 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,157,44)
226 0.300 seconds (measured here), 78.29 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,168,230)
226 0.282 seconds (measured here), 74.55 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,156,101)
226 0.239 seconds (measured here), 87.91 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,170,180)
226 1.298 seconds (measured here), 96.69 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,158,77)
226 1.216 seconds (measured here), 98.79 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,179,45)
226 1.002 seconds (measured here), 98.60 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,186,79)
226 1.258 seconds (measured here), 96.63 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,157,38)
226 1.428 seconds (measured here), 97.36 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,185,167)
226 1.624 seconds (measured here), 99.66 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,162,40)
226 1.449 seconds (measured here), 98.65 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,169,43)
226 1.498 seconds (measured here), 99.06 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,165,156)
226 1.171 seconds (measured here), 97.85 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,181,254)
226 0.188 seconds (measured here), 78.76 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,161,106)
226 0.028 seconds (measured here), 66.53 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,188,20)
226 0.170 seconds (measured here), 83.77 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,192,1)
226 0.002 seconds (measured here), 5.84 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,185,68)
226 0.094 seconds (measured here), 73.29 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,157,227)
226 0.003 seconds (measured here), 5.38 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,191,181)
226 0.094 seconds (measured here), 73.39 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,185,24)
226 0.118 seconds (measured here), 72.33 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,159,44)
226 0.154 seconds (measured here), 59.18 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,167,122)
226 0.311 seconds (measured here), 85.75 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,185,249)
226 0.002 seconds (measured here), 6.46 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,189,24)
STOR clientraw.txt
226 0.016 seconds (measured here), 46.50 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,191,96)
STOR clientrawextra.txt
226 0.059 seconds (measured here), 53.69 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,195,24)
STOR clientrawdaily.txt
226 0.021 seconds (measured here), 95.03 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,169,179)
STOR clientrawhour.txt
226 0.025 seconds (measured here), 100.03 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,172,15)
226 0.137 seconds (measured here), 51.26 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,169,2)
226 0.102 seconds (measured here), 53.06 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,158,212)
226 1.320 seconds (measured here), 96.51 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,159,10)
STOR climatedataout.html
226 0.186 seconds (measured here), 80.10 Kbytes per second
PASV
227 Entering Passive Mode (74,220,207,119,161,226)
226 0.151 seconds (measured here), 72.76 Kbytes per second
CWD public_html
550 Can’t change directory to public_html: No such file or directory
141: FTP protocol error: 550 Can’t change directory to public_html: No such file or
directory
PASV
227 Entering Passive Mode (74,220,207,119,182,46)
226 0.173 seconds (measured here), 63.27 Kbytes per second
Changing back to original dir for this file
CWD public_html
directory
PASV
227 Entering Passive Mode (74,220,207,119,181,137)
226 0.390 seconds (measured here), 94.08 Kbytes per second
CWD public_html
directory
PASV
227 Entering Passive Mode (74,220,207,119,156,118)
226 0.407 seconds (measured here), 90.63 Kbytes per second
CWD public_html
directory
PASV
227 Entering Passive Mode (74,220,207,119,159,204)
226 0.496 seconds (measured here), 93.35 Kbytes per second
No more files to upload
All Agenda complete, doing FTP log off…
FTP logoff
QUIT
221-Goodbye. You uploaded 2667 and downloaded 0 kbytes.
OK
Disconnected.
221 Logout.
Logging onto FTP server…tgftp.nws.noaa.gov
changing directory to /data/forecasts/zone/or/
Next file ftp down
Local directory for Noaa download is c:\wdisplay\downloads
Retrieving the NOAA file orz006.txt now
Saving the NOAA file to c:\wdisplay\downloads\orz006.txt now
Finished ftp download, loggin off from server
Doing abort procedure/program close…
that looks OK
was that FTP logfile for when the web site was corrupted?
re the error with the change in directory
check the file upload for the temp wind rain trend
you might have ticked to use this different remote directory
No, all looks good Brian. The website has been running perfect all day with no changes at my end… I don’t know how, but I think the problem is coming from my hosting service… I have had issues similar to this one, but this time it’s lasted for more than one day…
Bob
I would still fix that change in remote directory for those trend files
(email me your settings files if you can not find that setting)
Okay Brian, email sent
Looks like the setting Re remote directory
Has been fixed, via email
