I’m a newbie with consolewd. I set up the config.txt for my station (WF) and consolewd is logging data OK. When I enable FTP upload, the consolewd gets stuck with this message:
Current data 22:08:58: Temperature= 9.3 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=90 Barometer=990.3 Daily Rain=0.0 Rain Rate 0.0mm/min
WeatherFlow Data OK
Current data 22:08:59: Temperature= 9.3 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=90 Barometer=990.3 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 22:09:00
**** updating clientraw extra files
**** updating data logs
cronftpreal: no process found
…and doesn’t go on. I did change permissions to all files in the consolewd directory to ‘777’ but no success.
Continuation. I’ve manually started the cronftpreal and cronftp. The consolewd stucks here:
Current data 22:29:57: Temperature= 9.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=91 Barometer=990.5 Daily Rain=0.0 Rain Rate 0.0mm/min
WeatherFlow Data OK
Current data 22:29:59: Temperature= 9.1 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=91 Barometer=990.5 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 22:30:00
I’ve downloaded the new package but I think it’s same. It outputs the message that cronftp process was not found (same as before). In my config.txt I did enable the option that consolewd controls the cron jobs.
Running cronweatherflowconsole
WeatherFlow Data OK
Current data 22:58:00: Temperature= 13.8 Windspeed =0.0 Gustspeed =0.0 Direction =0 Humidity=78 Barometer=993.3 Daily Rain=0.0 Rain Rate 0.0mm/min
**** doing minute routines now 22:58:00
Bind failed with error
updating custom log now
I’ve then started cronftpreal manually. It started to upload the clientraw.txt until the round minute, when the consolewd updates the logs, etc.
pi@raspberrypi:~/consolewdfiles $ ./cronftpreal
Time 20 seconds
Remote name
Port to use 21
login OK to myftp
upload clientraw.txt to myftp OK
login OK to myftp
Terminated
If I disable the FTP in the config.txt file, the cronftpreal (started manually) uploads the clientraw.txt continuously with no crash. Is it possible that there is a problem with the cronftp (not cronftpreal)?
