Win 7, b90.
I don’t view this page of mine often so only noticed this this morning on the raindetail.gif: note that the Thursday day/date is reversed from the other days.
Roger
I am not seeing that here myself
anyone else seen that?
OK here in Win 10/build 90
Yep, checked mine when I read the post and it was the same here…build 92 on Win10Pro
same here means that its OK or its not OK?
its not very clear
doing the same thing as the original poster is more clear
otherwise its like you are saying its doing the same thing as me, which you replied to (and its OK for me)
people need to be very clear otherwise I can only guess, which leads to errors and so takes longer
the problem looks to be specific to is using USA date system and only for end of the month (and maybe only related to the 28th February which only comes around every 4 years)
I will do some investigating/checking
i have identified the bug
its been this way for 20 years
for when US date format in use
only at the change in the month was the correct US date format that is selected to be used in WD was used 8O
the next update of WD will fix this
Thanks Brian!!
BTW, Feb. 28 comes around every year :lol:
it was any month change it turns out (and yeah I was thinking of Feb 29)
build 93 has the fix (its not retrospective though but the new date format will flow through and fill in over the week)
