I upgraded WD to latest build and have problems. Wind speed is not correct, data freezing for few minutes. When is calm, it displaying minimum 0.4-0.7m/s constantly, never 0.0. I am back to build 81 and working correctly now. Please, do you can fix this problem for weatherhawk? Thanks.
Can you post a screen shot of the weather station type setup?
Also build 90 is not the latest,try the latest
Also it’s not clear if you updated from build 81 only
That you are using that now
The more detailed information you can provide the better
I’m currently using build 10.37S b81 and it works fine. I’ve also tried the last build and the problems with the wind speed show again. It is likely that the wind speed is blocked for a few minutes and several times a day. When there is calm, WD instead of 0.0 m/s displays the value of 0.4 or 0.7 m/s. 0.0 m/s never…
I was more meaning the weather station type setup screen in WD , via control panel
not that one
no, I am wanting to see the setup screen
control panel, weather station type setup
yes
that is what I was looking for
that should be using the serial connection and using the pakbus.dll file
you should not have had to use the setup screens you have posted already
there is some debug code under control panel, debug
what shows there
I do have another user of WD and the weatherhawk station and I did fix a problem with data spikes
and he has not otherwise reported the problem you are having
which is a bit hard for me to know exactly what the problem is. can you post a screen shot of say the graphs?
Ok. I will try update over setup file. Zip upgrade is not the best solution sometimes and reset registry entries…
I have never seen any reports of problems with the registry settings with the .zip update
just make sure to extract to where WD is installed
I’ve upgraded wd over setup instalation file, but problem the problem exists. Now, windspeed im my town is 0.0. Calm. WD displaying any value, see picture below.
I am struggling to know exactly what is not correct
the graph looks good, yes?
I think what you are saying is that its not displaying zero when there is no wind
what I need is to see the debug output (as per my post above), when that is happening
i.e under view, debug info
“I think what you are saying is that its not displaying zero when there is no wind”. Yes, it i s correct.
Debug info says:
Doing checking of time zone calculation
Daylight saving not in use
Loaded all time records
dodownloadupload
do2ndserverupload2
dodownloadupload
do2ndserverupload2
Please, see my banner. 1.9 km/h stay constantly. In my town not wind this evening.
it does not look like you are using the pakbus.dll
do you instead have the separate running cronpakbus program
yes?
is that program running?
also in the screen shot, that you posted, of the graphs, how much of that graph data is from the current version and how much is from the build 81 version
in the build 81 version, is the cronpakbus program?
I need to know as much detail as possible, otherwise I am just guessing
**Pakbus in data 1.727 #1
**Pakbus in data 13.8286 #2
**Pakbus in data 1.574 #3
**Pakbus in data 9.79636 #4
**Pakbus in data 1.574 #5
**Pakbus in data 1.574 #6
**Pakbus in data 67.12 #7
**Pakbus in data 1.8035 #8
**Pakbus in data 101.122 #9
**Pakbus in data 1.8035 #10
**Pakbus in data 102 #11
**Pakbus in data 8.55287 #12
**Pakbus in data 0.18315 #13
**Pakbus in data 2.033 #14
**Pakbus in data 13.4646 #15
**Pakbus in data 101.142 #16
**Pakbus in data -0.00214397 #17
**Pakbus in data 2.1095 #1
**Pakbus in data 31.4737 #2
**Pakbus in data 2.1095 #3
**Pakbus in data 9.79535 #4
**Pakbus in data 1.4975 #5
**Pakbus in data 1.4975 #6
**Pakbus in data 66.9811 #7
**Pakbus in data 1.4975 #8
**Pakbus in data 101.16 #9
**Pakbus in data 1.9565 #10
**Pakbus in data 6.80792 #12
**Pakbus in data 0 #13
**Pakbus in data 1.727 #14
**Pakbus in data 13.4663 #15
**Pakbus in data 101.14 #16
**Pakbus in data -0.00182558 #17
**Pakbus in data 1.3445 #1
**Pakbus in data 7.86306 #2
**Pakbus in data 1.3445 #3
**Pakbus in data 9.73007 #4
**Pakbus in data 1.3445 #5
**Pakbus in data 1.6505 #6
**Pakbus in data 66.7827 #7
**Pakbus in data 1.6505 #8
**Pakbus in data 101.171 #9
**Pakbus in data 1.6505 #10
**Pakbus in data 14.7698 #12
**Pakbus in data 2.4155 #14
**Pakbus in data 13.4419 #15
**Pakbus in data 101.162 #16
**Pakbus in data -0.00150624 #17
**Pakbus in data 1.574 #1
**Pakbus in data 50.174 #2
**Pakbus in data 9.81024 #4
**Pakbus in data 1.6505 #5
**Pakbus in data 66.7354 #7
dodownloadupload
do2ndserverupload2
**Pakbus in data 0.503 #8
**Pakbus in data 101.201 #9
**Pakbus in data 0.503 #10
**Pakbus in data 350.006 #12
**Pakbus in data 0.732601 #13
**Pakbus in data 13.4873 #15
**Pakbus in data 101.172 #16
**Pakbus in data -0.00125009 #17
**Pakbus in data 6.636 #2
**Pakbus in data 1.9565 #3
**Pakbus in data 9.784 #4
**Pakbus in data 0.8855 #5
**Pakbus in data 0.8855 #6
**Pakbus in data 66.6713 #7
**Pakbus in data 9.50916 #12
**Pakbus in data 0.8855 #14
**Pakbus in data 13.4906 #15
**Pakbus in data 101.173 #16
**Pakbus in data 0.7325 #1
**Pakbus in data 8.13168 #2
**Pakbus in data 0.7325 #3
**Pakbus in data 9.72186 #4
**Pakbus in data 1.421 #5
**Pakbus in data 1.421 #6
**Pakbus in data 66.627 #7
**Pakbus in data 1.421 #8
**Pakbus in data 101.166 #9
**Pakbus in data 1e-005 #10
**Pakbus in data 8.24772 #12
**Pakbus in data 1e-005 #14
**Pakbus in data 13.4537 #15
**Pakbus in data 101.143 #16
**Pakbus in data -0.00108543 #17
**Pakbus in data 45.8782 #2
**Pakbus in data 1e-005 #3
**Pakbus in data 9.69003 #4
**Pakbus in data 1e-005 #5
**Pakbus in data 1e-005 #6
It is seems as correctly…
that is the pakbus info I was looking for
when you say it seems correct, how do you mean exactly?
one thing
that scientific notation value
for windspeed
is probably part of the problem
WD ignores that value
that value might be occuring at low windspeeds?
I don
so that pakbus info was from build 81?
e.g this info
its not very clear
please, you need to be very clear in the information you are providing, otherwise I am just guessing
the latest version should be using that pakbus input but I suspect its instead using the cronpakbus.exe program (as at some point that has been set to be used)…that can be fixed
Uf…yes, I
