Hi all - Is there a way to scan automatically for highs and lows. My scrolling Hi/Lo banner has all sorts of figures which are generally wrong. As far as I recall the manual correction needs dates and times which are not easy to find so an autoscan would be nice.
Regards
Alan
You can try converting all found logfiles to datafiles which rebuilds all-time records which hopefully will sort out your highs and lows. If no joy with that then the erroneous values may be in the logfiles and will need to be edited.
yes, first reset the all time records that are wrong, then if your logfiles are correct, use the convert all (for converting logfiles to data files)
