Rain Reporting issues with WeatherFlow?
Just curious…
Is the rain data reported when looking at your WeatherFlow smart weather station data through your browser using the following link:
https://smartweather.weatherflow.com/share/{station ID}
You might have a defective SKY unit…
Yes, there is no problem with the SKY recording rain. It is not defective. I mentioned that in my original post. Also, in my post above I included a screenshot showing where you can see cronweatherflow, WD, and the station’s web page and as you can see the station reported rain, when WD and cronweatherflow didn’t.
in your raw OBS
“obs”:[[1554091912,24766,1.29,0,0.63,2.15,7.92,310,2.98,1,206,19.583]]}
the rain value is zero
what I need to know does that value change at all from being 0?
that is the value that WD uses
if not then that means there is something wrong on the weatherflow side
Hrmm, well, it stayed that way all day yesterday. Then late last night I did a datalogger extract set for the prior 72 hours and restarted WD so it pulled down all the data. At the end, it updated the WD daily rainfall to match what was reported via the weatherflow page. Today, I went up and banged the pole of the weatherflow to trigger a rain event (7.5mm) and WD still hasn’t reported any rainfall. I justlooked at weatherflowobs.txt and it is reporting ‘0’ in that delimited position in raw OBS. I have now closed and restarted WD again and it still shows 0 in that 4th delimited position
“obs”:[[1554198924,0,0,0,0,0.78,1.34,294,2.98,1,0,7.471]]}
So datalogger manual extraction seems to work, but not feeding in from weatherflow…API? Any idea on best next steps?
I suspect that there is a problem on their end that is just affecting you for some reason
I could make it an option to use the eg “precip_total_24h”:19.583, data instead
Thanks, Brian. I’m going to send this thread to their support and see what they say. If they can’t rectify it, perhaps you could add that option? Unless you want to just add it now regardless (not really sure I understand the implications of this, but I’m sure you do!).
Hey, Brian. Got an email back from my ticket with Weatherflow. They can’t see anything wrong, but said they will try to reach out to you. I’ve forwarded their response to [email protected] along with current backup files and weatherflowobs.txt from this morning (when it’s been raining and not showing up in WD still).
I know it’s the weekend for you so no rush, just whenever you get a chance to look into it!
But I have replied to you via email
So not sure why you are posting the same thing
Here?
All I need to know is does the value in the data position 3
Change when it’s raining, in the raw data, in the file weatherflowobs.txt
If this isn’t related then sorry about posting here…only had my Weatherflow for a few days but I notice a big problem with rain reporting as well. Just had a gully washer here, 0.02"/minute, and I still have my Davis Vue online so I can compare with WF. I have captured a couple screen grabs that show that SmartWeather is doing a good job of tracking the rain with my Vue, but WD on my iMac is way behind on the amount of rainfall. Note that the iMac is wireless to the WF hub and I have no way to know if that is a cause. But it is obvious that WD on the iMac is no where close to rain amount being recorded from the Vue or from the SmartWeather app.
The 1st attachment is showing the rain recorded by the Smartweather App, and the 2nd shows what WD on the iMac has picked up. For comparison, my WD on Win10 recorded 0.77" at the time of these screen grabs.
One solution is I add option
To use the rain total provided in the raw data
I
Instead of the rain amount since last rain recorded
Where some of those readings might get missed
I am away this weekend
Do can’t do anything until I get back
Sounds good to me, what do you think winedog?
I had already suggested to him I could do that
but it still would be good to know what is actually happening in his raw data , for the data position 3, while its raining
(that data needs to be checked often otherwise it goes to zero quickly (its not a rain rate …i.e the rain amount that has been recorded over the sample period (e.g every few seconds)
Guess I can’t help as I do not have a file called “weatherflowobs.txt” on my system.
WeatherFlow files in my webfiles directory:
weatherflow.txt
weatherflow0.txt
weatherflow1.txt
weatherflow2.txt
weatherflow3.txt
weatherflownames.txt
weatherflow2.txt should be the same thing
i have added option to use the 24hour calculated rain total now
to the latest mac version (which also fixes the solar plot), in the weather station type setup
and to this .zip update
With a tipping bucket, rain is collected and if it doesn’t evaporate (before tipping) you have a decent chance of measuring rainfall to some degree of accuracy. Now with the WeatherFlow (WF) I am not convinced that small amounts of rain are being stored/measured as we might expect. If WF is measuring and collecting the small amounts of rain then where is that data kept?
(Thinking out loud) I suspect it is being uploaded to the WF server and once the amount collected exceeds the “tip” amount then the WF server updates the smartweather app. Would be interesting to know how WF is tracking rainfall when it takes a long time to reach tip status.
Sitting here I just watched my WD/Vue combo record 0.02" of rain and so far nothing is showing on WD/WF combo (and nothing in smartweather app either).
it does not work that way , its recording individual drops of rain
Do you know where its being recorded/stored?
it reports rain since last measurement
that might be like 0.01mm
it will vary depending on the intensity
i would think you would be best to ask WF these sort of questions?
