does the rain raw data show in the separate running cronweatherflow program?
(last value in the column of values)
it could be that for some reason, for your weatherflow station, its not picking that up
(as I do not have any other reports of this problem)
what I need is a copy of your
weatherflowbobs.txt
from the webfiles folder
when its raining (maybe hit the pole to make vibrations)
Just coming back to this now that we have had a rainy day and the same thing seems to be happening where everything but precipitation is feeding into WD.
It appears that the rain raw data is not showing in the cronweatherflow program. I’ve attached the weatherflowobs.txt file as well. I’m not sure if this is relevant, but the file is timestamped 5:14pm today even though it is now 7:51pm. It has rained several times since 5:14pm, but there is no update.
Also wind and temperature data seem to be coming through just fine? It’s just the rain…
Yes, there is no problem with the SKY recording rain. It is not defective. I mentioned that in my original post. Also, in my post above I included a screenshot showing where you can see cronweatherflow, WD, and the station’s web page and as you can see the station reported rain, when WD and cronweatherflow didn’t.
in your raw OBS
“obs”:[[1554091912,24766,1.29,0,0.63,2.15,7.92,310,2.98,1,206,19.583]]}
the rain value is zero
what I need to know does that value change at all from being 0?
that is the value that WD uses
if not then that means there is something wrong on the weatherflow side
Hrmm, well, it stayed that way all day yesterday. Then late last night I did a datalogger extract set for the prior 72 hours and restarted WD so it pulled down all the data. At the end, it updated the WD daily rainfall to match what was reported via the weatherflow page. Today, I went up and banged the pole of the weatherflow to trigger a rain event (7.5mm) and WD still hasn’t reported any rainfall. I justlooked at weatherflowobs.txt and it is reporting ‘0’ in that delimited position in raw OBS. I have now closed and restarted WD again and it still shows 0 in that 4th delimited position
I suspect that there is a problem on their end that is just affecting you for some reason
I could make it an option to use the eg “precip_total_24h”:19.583, data instead
Thanks, Brian. I’m going to send this thread to their support and see what they say. If they can’t rectify it, perhaps you could add that option? Unless you want to just add it now regardless (not really sure I understand the implications of this, but I’m sure you do!).
Hey, Brian. Got an email back from my ticket with Weatherflow. They can’t see anything wrong, but said they will try to reach out to you. I’ve forwarded their response to [email protected] along with current backup files and weatherflowobs.txt from this morning (when it’s been raining and not showing up in WD still).
I know it’s the weekend for you so no rush, just whenever you get a chance to look into it!
If this isn’t related then sorry about posting here…only had my Weatherflow for a few days but I notice a big problem with rain reporting as well. Just had a gully washer here, 0.02"/minute, and I still have my Davis Vue online so I can compare with WF. I have captured a couple screen grabs that show that SmartWeather is doing a good job of tracking the rain with my Vue, but WD on my iMac is way behind on the amount of rainfall. Note that the iMac is wireless to the WF hub and I have no way to know if that is a cause. But it is obvious that WD on the iMac is no where close to rain amount being recorded from the Vue or from the SmartWeather app.
The 1st attachment is showing the rain recorded by the Smartweather App, and the 2nd shows what WD on the iMac has picked up. For comparison, my WD on Win10 recorded 0.77" at the time of these screen grabs.
One solution is I add option
To use the rain total provided in the raw data
I
Instead of the rain amount since last rain recorded
Where some of those readings might get missed
I am away this weekend
Do can’t do anything until I get back
I had already suggested to him I could do that
but it still would be good to know what is actually happening in his raw data , for the data position 3, while its raining
(that data needs to be checked often otherwise it goes to zero quickly (its not a rain rate …i.e the rain amount that has been recorded over the sample period (e.g every few seconds)
With a tipping bucket, rain is collected and if it doesn’t evaporate (before tipping) you have a decent chance of measuring rainfall to some degree of accuracy. Now with the WeatherFlow (WF) I am not convinced that small amounts of rain are being stored/measured as we might expect. If WF is measuring and collecting the small amounts of rain then where is that data kept?
(Thinking out loud) I suspect it is being uploaded to the WF server and once the amount collected exceeds the “tip” amount then the WF server updates the smartweather app. Would be interesting to know how WF is tracking rainfall when it takes a long time to reach tip status.
Sitting here I just watched my WD/Vue combo record 0.02" of rain and so far nothing is showing on WD/WF combo (and nothing in smartweather app either).
