Author Topic: Create Web Page Help Needed  (Read 795 times)
Offline chargedbird
  • Win NT 10.0
  • Chrome 71.0.3578.98
« on: February 20, 2019, 01:13:42 AM »
Grettings all,
Hey, I need a little help, I would like for my Public Web Page, being hosted by inmotion, (just and FYI), anyways I would like for the the default WD that shows up on my monitor.  I have all the FTP connections set and I can see the files are being put into the local drive, however they dont see to be uploading to my domain. I know this sound vague, but I don't know what else to say.  I am very lost here.  Are there any Videos I can watch on how to make a web page using Weather Display.  I did see a web page using the WDL and that would be cool too, but I don't know how to get the data from my desktop to the domain.  and I know for 100% is my settings in WD.  So what would be the easiest to get the FTP Working, just a simple test, would WDL be the way to try??
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Create Web Page Help Needed
« Reply #1 on: February 20, 2019, 01:41:44 AM »
what is the url to your web site?
Offline chargedbird
  • Win NT 10.0
« Reply #2 on: February 20, 2019, 06:05:24 PM »
Brain,
Here is my URL  Santeewx.com
I used the setup >> web page Creation Wizard and followed the directions....I also turned on Client viewer/AVG/WDL  and hit start.  I have not enabled any of those Internet File Creation and uploads.
The goal is to have the default display that I have on desktop monitor to be my web page....I love the setup of the WD Default Display...I'm easy....
WD is uploading the data, here is a my FTP Log file.
220 You will be disconnected after 30 minutes of inactivity.
USER=****
331 User snlwx@santeewx.com OK. Password required
PASSWORD=****
230 OK. Current restricted directory is /
TYPE I
200 TYPE is now 8-bit binary
Change to remote Dir /
CWD /
227 Entering Passive Mode (199,250,210,145,120,240)
150 Accepted data connection
226-File successfully transferred
226 0.078 seconds (measured here), 2.54 Mbytes per second
PASV
227 Entering Passive Mode (199,250,210,145,124,12)
226 0.051 seconds (measured here), 3.86 Mbytes per second
PASV
« Last Edit: February 22, 2019, 08:17:54 PM by chargedbird »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: February 20, 2019, 07:23:08 PM »
you have the index.html file uploading
which is a good start
you will need to also have the 24/48/72 hour graphs uploading
if you use the customise internet and file creation setup then you can set what files to upload
see this you tube video
http://www.weather-display.com/youtubevideos.php
and
https://www.youtube.com/watch?v=P62iZN6c1b8&feature=youtu.be
Offline chargedbird
  • Win NT 10.0
« Reply #4 on: February 20, 2019, 08:34:51 PM »
Ok, thank you for the info, I have been playing around with these for a few days and I am remembering where to go.....my questions to you sir:
1. Is the Saratoga Them the same them default them for WD.
2. Which File numbers do I need to upload, I believe its file number 29, (per the You Tube Video) and file number 11 curr 24/48/72 hour.
Just to be sure we are on the same page, do I need to have WDL switch on, currently on, and only have two files from the Internert File Creation uploading, file #11 and #29
Thanks again for helping me.....I am learning....so the questions will go away slowly....
Offline Budgie
  • Martin
  • Global Moderator
  • CWOP: CW7959
  • Lochaber, Scotland
  • Win NT 10.0
  • Firefox 65.0
    • Lochaber-Weather
« Reply #5 on: February 20, 2019, 11:26:14 PM »
Have a look at this FAQ for some hints on how to get the files setup & uploaded: https://www.weather-watch.com/smf/index.php/topic,53074.0.html
Offline chargedbird
  • Win NT 10.0
« Reply #6 on: February 21, 2019, 12:48:42 AM »
@Budgie  I have read them and I am still lost.....the figs are missing and what is the Carter Lake Style??  Where can I see it, the same with Saratoga.....
« Last Edit: February 21, 2019, 12:52:33 AM by chargedbird »
Offline chargedbird
  • Win NT 10.0
« Reply #7 on: February 21, 2019, 12:55:48 AM »
Now the figs show up....this is not my day!!!!!!!!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: February 21, 2019, 01:01:36 AM »
for some reason you now do have the index.html file on your web site
(you did before)
make sure that is being uploaded
what shows in the ftp log now?
Offline Budgie
  • Martin
  • Global Moderator
  • CWOP: CW7959
  • Win NT 10.0
  • Firefox 65.0
    • Lochaber-Weather
« Reply #9 on: February 21, 2019, 01:14:44 AM »
The Carter Lake Template is like the Saratoga template, only it's a basic version which should get you started.
As Brian has said, I think you need to make sure that files are being uploaded to the site to start off with. So check your FTP settings and the FTP log to see if any errors are there.
If you're not sure then post the contents of the FTP log on here so we can try to figure it out - remove any usernames & passwords though!  :wink:
Offline chargedbird
  • Win NT 10.0
« Reply #10 on: February 21, 2019, 01:33:43 AM »
Ok I did the Carter Lake template and I am still missing images on the site, here is a screen shot of the files upload to my site.  To let y'all know the files are going to my /public_html directory.  Almost got it just need a few graphs.    attached are the screen shots and here is my FTP Log:   Hey Budgie, thats for the excellent work on the FAQ that is what I needed plus I did learn some stuff, which means less questions....sometimes I need to hit save a few times before WD accepts it, I did read that it must have something to do with how many CPU's I am running.  Also currently I have the Real Time clientraw upload for Client Viewer/AVG/WDL turned OFF, I hope this is correct...but I like the baby steps, we are making progress, and I am so sorry for all the stupid questions, turst me, I have been playing around with this WD for about 7 days and there is just so much this software can do and sometimes I think I have it going into a circle ...wait...thats me.   :)    What do I need to do to show those graphics....  Thanks again, BH
« Last Edit: February 22, 2019, 08:18:12 PM by chargedbird »
Offline chargedbird
  • Win NT 10.0
« Reply #11 on: February 21, 2019, 01:47:53 AM »
Finally,
I ran those XHTML and CSS Validations, the CSS came back as W3C CSS Validator results for http://santeewx.com/ (CSS level 3), Congratulations! No Error Found.
XHTML:  Line 314,Column 36: element "h0" undefined <div class="headerTemp"><h0><span class="doNotPrint"> (the web page has the > sign in red after the 0 and before <span Class etc...)
You have used the element named above in your document, but the document type you are using does not define an element of that name.This error is often caused by:
•incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Frameset" document type to get the "<frameset>" element),
•by using vendor proprietary extensions such as "<spacer>"or "<marquee>" (this is usually fixed by using CSS to achieve the desired effect instead).
•by using upper-case tags in XHTML (in XHTML attributes and elements must be all lower-case).
I have no idea what this mean....ok fellows I am done for the day, but please keep those suggestions coming, I wil work more on tomorrow...
Ciao~ and thanks for teaching this old dog new tricks....
BH
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #12 on: February 21, 2019, 01:59:14 AM »
I see that you have WD set to upload jpg image
unset that
in the control panel, webfiles/web page setup (setup #1)
Offline chargedbird
  • Win NT 10.0
« Reply #13 on: February 21, 2019, 08:44:22 PM »
Winner Winner Chicken Dinner, that fixed my problems, how I have images.... thank you so much Brain and Budgie!!!!  Now I can play around with this...going to make a backup right now!!!!!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: February 22, 2019, 12:02:16 AM »
you can edit the template file (mywebpagetemplate.txt)
