Ok now I understand.
Thanks Wim!
I really like your template. Now that you have the new wunderground forecasting working it is perfect.
I am having one problem with the wunderground forecast. I like 4 days forecast but I am getting no precipitation chance percentage. When I run w34_module_test.php and run forecastWUblock.php the %'s are there but not on the main page.
My website is http://vertical.skisantafe.com/waptx/pwsTEST/. My data is from South Dakota in case your wondering.
Edit: I went to wunderground and got a new api key right after I setup this beta. I’ve now figured out that the forecast is Dark Sky not WU. I don’t know why I’m not getting WU.
You have to select in easyweathersetup that you want to use WU as forecaster. You could also select WXSIM if you have that product.
I’m an idiot. I looked at that and just couldn’t see it.
I was looking at the production version of w34_livedata.php and noticed that average and max wind speed are both defined using clientraw #158, which is “10-minute average wind speed (kts)”
$weather[“wind_speed_avg”] = convert_speed ($wd[158],$from,$to); and
$weather[“wind_speed_max”] = convert_speed ($wd[158],$from,$to);
I checked and it is still the same in beta. Maybe it doesn’t matter because we don’t show max wind speed anywhere, do we? Max gust shown uses CR#71.
But I would prefer the beta to make it clearer that the small “Average” value shown at top left of the Wind|Gust block is the 10-minute average, as is done in production.
Hi Wim,
There is still a probem with metar_load_function.php
regards
Tim
http://weather.skybase.net/pwsTEST/index.php
The airport uploaded a very short metar,
YSRI 042000Z AUTO 00000KT 9999 // OVC015 21/19 Q1017
but still no reason for the provider to miss some info.
I will add debugging code tomorrow and see if it happens again. It is fine that we still have full error reporting, otherwise this was not seen.
beta version 1-3-19 gives error in MS edge as
Notice: Undefined offset: 1 in /pwsWDTEST/metar_popup.php on line 203
Notice: Undefined offset: 1 in /pwsWDTest/metar_popup.php on line 205
CheckWX appear to be moving the goal post again re there data output file changing
@ALL
The format of the JSON file from the METAR provider has changed again.
Sorry, this should not have been visible for the production version. Still it is.
For the beta version all errors are displayed by default.
As I am “off the grid” for at least 3 weeks after tomorrow I have very little time left to find a solution.
FOR NOW: Start easyweather and select nearly at the bottom at the question
“Where do we get our current conditions from?” => “Use Darksky for current conditions (needs API key).”
That way your main window will not load the METAR scripts.
And do not use the “nearby” pop-up for now until i have had a chance to find out why they removed the airport name and others from the .JSON
METAR CHANGES for pwsTEST
As other users already discovered, the layout changed again.
[ol]
[li]The airport-name is not available anymore / for now??.[/li]
[li]The date/time field layout changed from:
old: 01-03-2019 @ 07:20Z"
new: 2019-03-05T05:55:00.000Z[/li][/ol]
I attach a zip with the two changed scripts for the pwsTEST users.
First make a copy of the two scripts you are going to replace.
These two scripts are only tested with the latest (a few day old) beta release.
The updates for the pwsWD version is posted in the other topic.
pwsTEST.zip (9.8 KB)
Wim,
Working fine for my pwsTEST1.
Also worked on my nonbeta pws.
Tom
Total hours between total darkness to total daylight are over 24 hours in sun moon & space block.
Should it be 24 hours total.
Torjan
Probably not quite exactly 24 hrs; but I do notice that the “total darkness” figures in the main Sun block are very different to those in the “Moon info” popup? (At the beta test sites and in production version here.)
This difference seemed to be an error. I will check when I am back home.
The total can only 24:00 hours when it is 24 hours dark or 24 hours daylight. Otherwise the darkness periode starts in one day and ends in another.
I question whether you really need the hours of darkness. If you show the length of day(light) the darkness is implied.
Only approximately unless, as Wim says, you have 24 hours’ day or night.
Are we confusing sunrise/sunset with civil, nautical or astronomical dawn/dusk somewhere? Original Sun block or pop-up showed times of civil dawn/dusk (elevation -6
Agreed, but what value does “hours of darkness” have?
None at all. . . except to enable the pretty graphic.
Moon set getting a little confusing. . . in production here and Gelderland beta.
Cloud cover in Gelderland beta Current Conditions is always in Dutch, whatever the selected language.
