I generated a [color=blue]XREF ( Cross Reference list )[/color] of the weather-icons versus the scripts they are used and the descriptions from those scripts.
That should help to find the wrong icons < > description in the future.
The forecast/current-condition scripts used have also their individual files
:oops: This was another error in the script. It did not check the absence of wind, forget to put this version online.
This version works better, has also wind in m/s.
I have the beta version running on my synology 214 but it is not accessible from the outside world but the metar popup has given an error message between the dew and humidity when the humidity is 100% appears to refer to line 92 of the metar_popup.php see attached
has the latest metar_popup.php on and have put todays metar_load_funct.php file on in place of the previous update
Hello
I’m noticing a difference between the last beta and the normal version in the “Moon phase”
The dawn Moon of tomorrow has 2 different fliers, in one score at: 4:44 in that test it marks: 5:25
is a mistake?
Thank you
Maybe I am looking at the wrong place? But I dot not see the same information you mention.
January version and beta are the same for today = March 2 rise 04:44 moonset 13:56
January version has no data for March 3
The main page of the beta version displays “upcoming data” so it says “MoonRise 05:25 tomorrow”
The January version displays “Moon rise 04:44” which could be considered incorrect as it should have been worded “Moon rose 04:44” bacause the displayed time is in the past. Strange thing is that for sun-rise/set we are accustomed to a sunrise in the past when it is daylight.
But not for the moon, there the times should be about future rise/set, because we can not see were the moon is during daytime.
At least that was how it was explained to me. All times for sun/moon - rise/set are future times and have the word “tomorrow” added or the exact date.
I really like your template. Now that you have the new wunderground forecasting working it is perfect.
I am having one problem with the wunderground forecast. I like 4 days forecast but I am getting no precipitation chance percentage. When I run w34_module_test.php and run forecastWUblock.php the %'s are there but not on the main page.
Edit: I went to wunderground and got a new api key right after I setup this beta. I’ve now figured out that the forecast is Dark Sky not WU. I don’t know why I’m not getting WU.
I was looking at the production version of w34_livedata.php and noticed that average and max wind speed are both defined using clientraw #158, which is “10-minute average wind speed (kts)”
$weather[“wind_speed_avg”] = convert_speed ($wd[158],$from,$to); and
$weather[“wind_speed_max”] = convert_speed ($wd[158],$from,$to);
I checked and it is still the same in beta. Maybe it doesn’t matter because we don’t show max wind speed anywhere, do we? Max gust shown uses CR#71.
But I would prefer the beta to make it clearer that the small “Average” value shown at top left of the Wind|Gust block is the 10-minute average, as is done in production.
