HWS-template (WD34) beta test topic
Current conditions says “Mostly Cloudy” but icon shows rain
I have been running the beta for two days now.
The WxSim forecast works on the 5 and 11 AM forecasts but hasn’t worked on the 5 PM forecast. I get the message ‘wxsim file not ready’. When I use the wxsimPP/_test.php I do get the WxSim forecast.
Also it doesn’t show the graphs using the database (it does in the non-beta version). It will graph using WU.
Can be seen here: https://www.shermanctweather.org/pwsTEST/
Tom
#-o The converted plaintext.txt /jsondata/wxsimpp_en.arr has only 7 day-parts is that correct or is the file incomplete?
The scripts check if there are at least 8 dayparts.
If your files have only 7day- in the same wayparts, change line 39 in forecastWXSIMblock.php to
if (!isset ($arr_pp) || count ($arr_pp) < 6 ) {echo ‘wxsim file not ready’; return;}
The pop-ups should also be changed, but that is for tomorrow as i live in CET
I could not reproduce as when i checked the text and icon are the same.
I will check daytime tomorrow as it is 00:40 CET here.
wim
Wim,
Changing that line fixed the WxSim forecast.
Tom
Maybe this is just one time strange glitch. I will watch it to see if it happens again
Added the “new” WeatherUnderground forecast to be included in the upcoming release. http://wd34.weather-template.com/pwsTEST/
The new API-keys are not yet available (only a few developers got one) until all problems are ironed out in the “how to obtain your key” process. As soon as one has got the e-mail and generated a NEW WU-api-key, sent me a PM for the download.
Based on the mails from WU it will be early next week until a new beta will be available to all.
Small problems with the WU data:
[ol][li]Missing description of some fields, f.i. iconCodeExtend[/li]
[li]The 3 temperature fields: temperature temperatureHeatIndex temperatureWindChill seems to be unrelated to each other, example for a night and the following day in Celsius :
temp 0 heat 7 chill -1
temp 13 heat 12 chill -1[/li]
[/ol]
Need to study the documentation if the explanation is hidden somewhere.
With the API-key one can also download 7 days of history, in JSON format. Could be used for the graphs also, but seems to have no advantages yet compared to the .CSV downloads from WU.
The METAR-data layout changed, the humidity field is now an array.
Attached new version ONLY for the beta test pwsTEST, not to be used for the normal pwsWD version.
metar_load_funct.php.zip (3.66 KB)
I generated a [color=blue]XREF ( Cross Reference list )[/color] of the weather-icons versus the scripts they are used and the descriptions from those scripts.
That should help to find the wrong icons < > description in the future.
The forecast/current-condition scripts used have also their individual files
[ul]
[li]DS → [color=blue]DarkSky[/color][/li]
[li]EC → [color=blue] Environment Canada[/color][/li]
[li]MT → [color=blue]Metar[/color][/li]
[li]PP → [color=blue]WXSIM plaintext parser[/color].[/li]
[li]WD → [color=blue]WeatherDisplay[/color][/li]
[li]WU → [color=blue]WeatherUnderground[/color][/li][/ul]
The XREF-pdf uses the original weather34 icons. The individual pdf’s use another set of icons I am currently testing with.
I have an error occasionally with metar_load_funct.php as per pic attached…
regards
Tim
http://weather.skybase.net/pwsTEST/index.php
I just opened the metar popup and I noticed an error
see attachment
https://weatheryyc.com/pwsTEST
3 messages up in this topic, they changed the layout of the JSON. New script is there.
I just downloaded a newer script that I found on here. I get the same error
:oops: This was another error in the script. It did not check the absence of wind, forget to put this version online.
This version works better, has also wind in m/s.
metar_load_funct.php.zip (3.7 KB)
good now. :smiley:
Thank you
I have the beta version running on my synology 214 but it is not accessible from the outside world but the metar popup has given an error message between the dew and humidity when the humidity is 100% appears to refer to line 92 of the metar_popup.php see attached
has the latest metar_popup.php on and have put todays metar_load_funct.php file on in place of the previous update
=D> Thanks for spotting this one.
Now 100% will display correctly,
metar_popup.php.zip (5.8 KB)
Final Beta version for the april release can be downloaded from http://wd34.weather-template.com/beta.php
Thanks for all help,
Hello
I’m noticing a difference between the last beta and the normal version in the “Moon phase”
The dawn Moon of tomorrow has 2 different fliers, in one score at: 4:44 in that test it marks: 5:25
is a mistake?
Thank you
pws: https://stazione.meteosantangelo.it/pws/
Test: https://stazione.meteosantangelo.it/pwsTEST/
Maybe I am looking at the wrong place? But I dot not see the same information you mention.
January version and beta are the same for today = March 2 rise 04:44 moonset 13:56
January version has no data for March 3
The main page of the beta version displays “upcoming data” so it says “MoonRise 05:25 tomorrow
The January version displays “Moon rise 04:44” which could be considered incorrect as it should have been worded “Moon rose 04:44” bacause the displayed time is in the past. Strange thing is that for sun-rise/set we are accustomed to a sunrise in the past when it is daylight.
But not for the moon, there the times should be about future rise/set, because we can not see were the moon is during daytime.
At least that was how it was explained to me. All times for sun/moon - rise/set are future times and have the word “tomorrow” added or the exact date.
You can check the moonrise/set for your place (or for any other place) : Moonrise, Moonset, and Moon Phase in Padua
