Author Topic: Apperantly i have failed to communicate about rain records  (Read 366 times)
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
  • Chrome 70.0.3538.102
« on: February 12, 2019, 10:46:45 AM »
Please see attached image.  Today I hit the record rain rate for the month and year.  Even though I have in/hr selected the number displayed is in/min.
Thanks for all you do.
Jim
  • Davis VP2
  • Chrome 71.0.3578.98
    • Weather Display
Re: Apperantly i have failed to communicate about rain records
« Reply #1 on: February 12, 2019, 05:45:36 PM »
where do you have in/hr selected exactly?
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #2 on: February 12, 2019, 05:56:02 PM »
In the current records screen.  See attached.
  • Davis VP2
    • Weather Display
« Reply #3 on: February 12, 2019, 06:06:21 PM »
if you unset that setting
does the value change?
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #4 on: February 12, 2019, 06:10:10 PM »
I can only change to in/min, in which case it changes to 0.000 since .026/60=.00043 and presents no significant digits.
  • Davis VP2
    • Weather Display
« Reply #5 on: February 12, 2019, 06:12:45 PM »
so the value does change
the code is showing the stored record value as *60 if you have set to show per hour
but it looks like the stored value , for the data from your weather station type, is wrong (needs to be stored as the value *60)
or something like that
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #6 on: February 12, 2019, 06:16:05 PM »
Could be.  It used to be right, I don't recall when it changed.  I have an ambient 2902A and in its setup the "Use Station Rain Total" box is checked.
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #7 on: February 12, 2019, 06:18:50 PM »
One more thing, in ambientdata, its showing hourly rate correctly.
{"dateutc":1549995360000,"winddir":186,"windspeedmph":0.2,"windgustmph":1.1,"maxdailygust":10.3,"tempf":54.7,"hourlyrainin":0.31,"eventrainin":3.33,"dailyrainin":2.19,"weeklyrainin":3.33,"monthlyrainin":3.78,"totalrainin":11.46,"baromrelin":29.91,"baromabsin":27.95,"humidity":99,"tempinf":73.4,"humidityin":49,"uv":0,"solarradiation":19.94,"feelsLike":54.7,"dewPoint":54.42,"lastRain":"2019-02-12T18:16:00.000Z","date":"2019-02-12T18:16:00.000Z"},"info":{"name":"Stanley Rapids","location":"Home"}}]
  • Davis VP2
    • Weather Display
« Reply #8 on: February 12, 2019, 06:28:55 PM »
I see the problem
I was storing the record value as divided by 60
for your station type and when set to use the rain rate provided by the station
when I should have been storing it (for the record value) as not divided by 60
I either now then display the value as *60 again
or fix the code
so for the next record it displays correct
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #9 on: February 12, 2019, 06:33:18 PM »
Thanks.  Best wishes.
Jim
  • Davis VP2
    • Weather Display
« Reply #10 on: February 12, 2019, 06:40:06 PM »
i think fixing the original value best approach
so that moving forward your next records that are beaten are correct
yes?
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #11 on: February 12, 2019, 06:43:47 PM »
I leave that to you.  There will always be a next record, in my case it's likely to be later today as there is substantial rain continuing to move my way.  But, as you please.  It will be fine with me either way.
Jim
  • Davis VP2
    • Weather Display
« Reply #12 on: February 12, 2019, 06:52:19 PM »
I have gone with the above in the latest .zip update for you to try
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #13 on: February 12, 2019, 06:54:48 PM »
Got it.  I'll let you know if there is a future problem.
Thanks again.
Offline jaltman
  • Ambient 2902A
  • Blue Ridge, GA.
« Reply #14 on: February 12, 2019, 07:08:28 PM »
Looks good.  The stored value, being so low, was rapidly replaced by the current rain rate and all is well.
Jim
