Author Topic: WD stops, and fails in multiple data areas  (Read 477 times)
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Shelby Ohio Weather
« on: February 11, 2019, 01:58:42 PM »
I hope that someone can help out with this mess I am dealing with. I think either my brain stopped thinking at the age of 55, or WD is somehow messed up, (personally I believe it is the latter)  :) So here goes nothing...
System #1 (main system)
WD - 10.375 build 90 - with latest update
Ambient Weather WS-2902A Smart WiFi
Windows 7 Pro laptop, Pentium Dual Core CPU, 8 GB Memory, 64 bit operating system
Backup System #2 - (incase of primary failure, I can switch to this one)
Windows 10 Pro, Intel core i7, 64 GB Memory, 64 bit operating system
Problem(s) are as follows...
1)  (Main Problem) WD looses the WS-2902A Ambient weather key, and MAC address every so often, then goes on a tagent, with wild data numbers.
2)  Twitter stops (not sending much data to make it stop,  I read in the forum about it)  and keeps asking to re authorize (I do keep resetting it, but after awhile, it comes up to ask for a re authorize
3)  web cam setup and attachment not working (also read all problems and solutions in the forum, none work) Camera is a foscam
4)  web pages not updating correctly, or not at all on the web site. the files are being created correctly on the computer, but fail to correctly ftp update to the website.
5)  Screen resolution on the weather pc is 1366 x 768, and for some reason, it will not show everything on the main screen. this also happens on the backup (or my PC, which has a resolution of 1920 x 1080}. I can see more to the right of the main screen when I do a small resize, but it will only show the main screen, and nothing to the right
« Last Edit: February 11, 2019, 02:28:54 PM by OhioRVHawk »
Ambient Weather WS-2902A Smart Weather Station with WiFi
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: WD stops, and fails in multiple data areas
« Reply #1 on: February 11, 2019, 06:34:54 PM »
are you running WD as administrator?
re screen size, you can set to modify the main screen and then resize it as needed
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
« Reply #2 on: February 11, 2019, 08:56:55 PM »
If it is on the older windows 7 -main weather computer- no.    If I run it on the win 10 - yes
Should I also do that for the main win weather computer as well??
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: February 11, 2019, 09:49:58 PM »
not sure what you mean exactly?
its not very clear to me
do you you mean you have WD running on 2 pc's, or?
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
« Reply #4 on: February 11, 2019, 10:17:24 PM »
No, you asked me if I am running it as administrator.  my reply was this, I am not running it as administrator on the Win7 Dedicated weather only laptop. and I only run it there 24/7/365
The Regular Computer I have it there, but it is Not running Unless the Dedicated Weather Laptop somehow fails, or WD fails on there. But it is Never running on my regular Laptop.
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #5 on: February 11, 2019, 11:25:06 PM »
Which of the two PC's does your list of problems apply to?
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #6 on: February 11, 2019, 11:30:24 PM »
it is a bit confusing
is it the windows 7 pc where the problem is occuring?
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
« Reply #7 on: February 11, 2019, 11:39:28 PM »
yes
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #8 on: February 12, 2019, 09:38:52 AM »
re the foscam camera
did you try this version of the web cam program?
http://www.weather-display.com/downloadfiles/wdwebcamcapture.zip
for the web site not updating
what shows in the ftplogfull.txt ?
for the fist issue, I have not seen other reports of that particular problem
strange
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
« Reply #9 on: February 12, 2019, 11:10:02 AM »
*******warning email send********
Connecting to mail server.
OK
Connected.
OK
Disconnected.
CURRENT WEATHER REPORT FROM: Shelby Ohio Weather
Conditions: Stopped snowing
Temperature: 30.2 F(-1.0 C )
Trend: -0.4 F /hr
Average windspeed: 0.0 mph
Current speed: 0.0 mph
Direction: ESE  111
Barometer: 30.120 in. (1020.0 hPa )
Pressure trend +0.000in./hr
Humidity: 79 %
Dew point: 24.5 F
Todays rain: 2.780 in. snow
Monthly rain: 2.780 in. snow
Yearly rain: 20.690 in. snow
Maximum temperature: 32.5 F (0.3 C) at time: 10:24 AM
Minimum temperature: 20.7 F (-6.3 C) at time: 12:00 AM
Maximum gust today: 4.6 mph E at time: 9:00 AM
Max gust last 10 mins: 2mph
Current Heatindex: 30.2 F
Snow for today: 2.780 in
Snow for month: 2.780 in
Snow for season: 20.690 in
Solar radiation: 0.0 w/m2
Sunshine hours for year: 9.2
Sunshine hours for month: 9.2
Sunshine hours for day: 0.0
Created by "Weather Display" version 10.37S Build 90 7:43:09 AM 2/11/2019
Time of Weather report: 7:00:52 PM Date of report: 2/11/2019
Sending email to server 192.254.241.25
301: Interrupted.
Offline OhioRVHawk
  • Shelby Ohio
  • Win NT 10.0
« Reply #10 on: February 12, 2019, 11:34:58 AM »
As for the screen size, I managed to get a normal screen shot, and one of me doing a resize, just before a snap back to normal
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #11 on: February 12, 2019, 05:44:15 PM »
you have posted info about sending an email that is failing but you mentioned about uploads to your web site failing?
for the email, it looks like it might be a problem with the it being secure email but you have not set that it is
for the screen problem, at what point in time does it change?
i.e after how long, etc?
you could try resetting the screen customisation:
setup, advanced/misc
main screen customisation
click on start over main
then restart WD
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #12 on: February 12, 2019, 05:46:09 PM »
yes
You do need to run it as Administrator on W7.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #13 on: February 14, 2019, 06:23:37 PM »
re the problem with the email
what is your email provider?
if you could email me your email settings I could test here
