WD appears to be running okay but I can’t view it. If I click on the icon on the task bar a small black box pops up but it blank. It is updating Internet files but I cant make any changes to the options. I have un-installed the program and did an install of the latest version. Windows 10.
I installed the program to a different directory and that solved the issue. I have been running the program for around 12 years or so. Thanks for the advice.
It was probably a setting in the
Wdisplay.ini settings file
Where WD was normally installed
For the last main screen size ( width / height)
You should be able to reset that in that file
