Author Topic: Crashing WD and confusion  (Read 251 times)
Offline chief-david
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Robbinsdale Middle School Weather
« on: February 08, 2019, 04:06:27 PM »
WD has been locking up every 4-6 days. I get a few codes with a lot of popup boxes
Quote
Exception  EOSerror in module weatherdisplay.exe at 000363E1 (also had 000c688c)
system error code 8
Not enough memory
resources are available  to process this command.
When it happens- it locks up sending to webcam, PWS, twitter, and WU. It also opens a 2nd webcam.exe program
Then I cannot connect Team viewer to solve the issue.
I have to restart the computer to correct the issue.
Here is my error log from WD.
Quote
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 7:57:1:34 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 8:11:0:971 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 8:13:0:963 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 8:14:0:959 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 9:14:0:913 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 9:43:0:899 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 9:45:0:881 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 10:14:0:839 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 10:15:0:877 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 10:23:0:844 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 11:30:0:766 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 12:1:0:764 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 12:26:0:743 02/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 12:56:0:718 02/05/2019
Current warmest day value (oC) -15.0 6:00:02 PM 02/05/19
Resetting coldest night values 6:00:31 PM February/05/2019
Resetting coldest night values 6:01:31 PM February/05/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 1:39:1:5 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 2:1:1:11 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 3:49:0:853 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 4:31:0:874 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 4:45:0:873 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 5:1:0:826 02/06/2019
Current coldest night value (oC) -11.5 6:00:02 AM 02/06/19
Resetting warmest day values 6:00:31 AM February/06/2019
Resetting warmest day values 6:01:31 AM February/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 6:37:0:746 02/06/2019
error with create customclientraw file  Invalid file name - %s
Current warmest day value (oC) -8.3 6:00:02 PM 02/06/19
Resetting coldest night values 6:00:31 PM February/06/2019
Resetting coldest night values 6:01:31 PM February/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 21:22:0:941 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 21:51:0:886 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 22:15:0:873 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 22:26:0:873 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 22:44:0:842 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 22:57:0:850 02/06/2019
ERROR: Cannot open file "S:\RMS\Weather\webcam.jpg". The process cannot access the file because it is being used by another process  System.Classes at time/date 23:20:0:848 02/06/2019
Current coldest night value (oC) -7.3 6:00:01 AM 02/07/19
Resetting warmest day values 6:00:31 AM February/07/2019
Trying to decide if it is WD, network, or computer
Vantage Pro Plus 6163
KMNMINNE28
CWOP DW6947
Midwesternweather.net
twitter @RMSWeather
  • Davis VP2
  • New Zealand
  • Android 7.1.1
  • Chrome 71.0.3578.99
    • Weather Display
Re: Crashing WD and confusion
« Reply #1 on: February 08, 2019, 07:08:29 PM »
The first error reports not enough memory
That is the clue
Which version, build of WD
You could try an older version or set WD
To restart daily
Offline chief-david
  • Win NT 10.0
« Reply #2 on: February 08, 2019, 09:10:18 PM »
I just updated it from something like r252 to s88/89.
It has done it once since then. Waiting to see if it does it again.
If it continues, I can look at the restart option. Where is that? Will it close and reopen webcam.exe also?
I  only run
WD
Weatherlink
Startwatch
Virtual VP
Teamviewer
UPS software
Chrome
« Last Edit: February 08, 2019, 09:13:28 PM by chief-david »
KMNMINNE28
CWOP DW6947
twitter @RMSWeather
Offline chief-david
  • Win NT 10.0
« Reply #3 on: February 13, 2019, 02:07:29 PM »
had it again. Caught it while at school.
Still looking for how to restart WD daily. Cant do it on Startwatch. Need help.
KMNMINNE28
CWOP DW6947
twitter @RMSWeather
Offline ed2kayak
  • CoCoRaHS PA-CD-6, Weather Underground KPAMECHA7, CWOP DW5425
  • Mechanicsburg PA
  • Win NT 10.0
  • Chrome 72.0.3626.96
    • Cumberland Valley Weather
« Reply #4 on: February 13, 2019, 03:31:39 PM »
CP>FTP & Connections>Reboot/restart
I reboot mine every day at 03:28
Works 100% of time.
Ed
Offline chief-david
  • Win NT 10.0
« Reply #5 on: February 14, 2019, 02:20:17 AM »
Thanks. I am going to set it to just restart WD and only on weekdays. See if that works.
I have to log in to my computer and it is not set to auto login.
Just would like to know what changed. It did not do this until a few weeks ago.
KMNMINNE28
CWOP DW6947
twitter @RMSWeather
Offline DopplerDavid
  • Boonsboro, Maryland USA
  • Win NT 10.0
  • Chrome 64.0.3282.140
« Reply #6 on: February 14, 2019, 02:47:53 AM »
Same thing happening with my WD .
First started about 2 weeks ago.
Checked set-up Tab Wizard to find that the "weather station set-up" page input data was erased.
This happened two or three times .
Now Data is showing on VP Display console  and data refresh light in WD is flashing, but readings have been frozen  for two days!
Not sure what is happening.
DD
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: February 14, 2019, 03:07:49 AM »
re its not currently working
what shows under view, debug info
after setting in WD
setup, advanced/misc
tick to log the raw data
Offline chief-david
  • Win NT 10.0
« Reply #8 on: February 14, 2019, 08:27:33 PM »
on the wecam.exe page
does the checkmark "restart regularly' restart the program or the camera???
KMNMINNE28
CWOP DW6947
twitter @RMSWeather
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: February 14, 2019, 08:51:05 PM »
just stops and then restarts the camera
