Author Topic: How to keep Outside Humidity readings from reporting.  (Read 126 times)
Offline JR
  • Win NT 10.0
  • Chrome 71.0.3578.98
« on: February 07, 2019, 08:45:26 PM »
My outside humidity sensor is not reporting properly so I want to keep it's erroneous readings off my Weather Display screen as well as my Weather Underground site.
Indoor humidity has a toggle switch.  Does Outdoor Humidity have a 'switch' also to keep it from reporting and or showing on Weather Display?
(I have an aging Davis WMII on the roof and will not be replacing the sensor any time soon, though that would be the ultimate solution)
  • Davis VP2
  • New Zealand
  • Android 7.1.1
  • Chrome 71.0.3578.99
    • Weather Display
Re: How to keep Outside Humidity readings from reporting.
« Reply #1 on: February 08, 2019, 12:55:13 AM »
You could set WD to use the humidity reading
From a downloaded near by metar
Offline JR
  • Win NT 10.0
« Reply #2 on: February 08, 2019, 01:01:37 PM »
That appears to just what I need!  Thanks
Now I need to get it to work.  Several options to consider  such as .txt vs .taf?
It is saving a .taf file to my computer but it is not showing up on my station report.
Don't know if there is any trick to it but I will trial and error it.
  • Davis VP2
  • New Zealand
  • Android 7.1.1
    • Weather Display
« Reply #3 on: February 08, 2019, 07:02:35 PM »
Make sure you have the latest WD update
As noaa changed to using https
