Author Topic: AAG_WeatherCenter Files  (Read 228 times)
Offline jerryyyyy
  • Win NT 10.0
  • Firefox 65.0
« on: February 05, 2019, 12:31:28 AM »
Hello, in my new install of my observatory software I have another problem,
I use AAG_WeatherCenter and AAG_CloudWatcher for my cloud sensor to set parameters to close the roof.
Using the Internet File Creation settings, it seems that WD is not creating a new:  AAG_WeatherCenterWD.htx to be read by AAG_WeatherCenter.  Dates remain the same on file.
Any suggestions on this?.
JY
« Last Edit: February 05, 2019, 01:38:29 AM by jerryyyyy »
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
Re: AAG_WeatherCenter Files
« Reply #1 on: February 05, 2019, 01:14:57 AM »
WD does not create .htx files
you might be getting confused with cumulus?
WD  can be set to create custom files though
from a template file (maybe that is missing)
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
  • Win 7/Srvr 2008R2
« Reply #2 on: February 05, 2019, 01:22:40 AM »
He's had it working for a couple of years with WD, I think it must be a tag file template thing.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: February 05, 2019, 01:59:52 AM »
he might not have the template file or similar (the one that has the custom tags in it)
can only guess as there is not much detailed info provided
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #4 on: February 05, 2019, 02:46:23 AM »
The jpg screenshot is very hard to make out but looks like it uses the Special File Conversion from _WeatherCenterWD.htx - so I guess it's missing that file :dontknow:
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: February 05, 2019, 02:49:27 AM »
at a guess, yes
Offline jerryyyyy
  • Win NT 10.0
  • Firefox 65.0
« Reply #6 on: February 05, 2019, 06:50:02 AM »
Thanks for the comments, this is making more sense as a template... that is what the file looks like.  The "tag" file I guess has the suffix of .htx not html or htm.  Let me append a copy with a .txt appended.  Maybe this is a lost ability of WeatherDisplay.
This is the help file for AAG_WeatherCenter and there is an entry for WeatherDisplay settings.
http://lunatico.es/aagcw/wc/enhelp/indexh.htm
I may have it working now because WeatherDisplay seems to produce an htm file using the htx template and if I feed the htm NOT the htx into AAG_WeatherCenter, the WeatherCenter display works.
FYI, the goal of the maneuver is to have AAG_WeatherCenter set a stop bit is a safety binary when weather consitions go out of sort.  The AAG_CloudSensory does this for the clouds... together they form a pair that shuts to roof if either is bad.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #7 on: February 05, 2019, 10:28:38 PM »
I had no problem making this work using your .htx template file (in wdisplay\webfiles) and correctly generating a .htx output file with the tags populated with values.
Offline jerryyyyy
  • Win NT 10.0
  • Firefox 65.0
« Reply #8 on: February 05, 2019, 10:55:06 PM »
Thanks, could you possibly show me what your settings look like?  I had to change the output to htm and use the htm in the AAG program.  You are sure the htx is updating?
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #9 on: February 05, 2019, 11:29:40 PM »
I just did a really basic one minute update setup. I changed the template and output filenames when testing to be sure that it was working as expected. The time in the output file is Pacific.
« Last Edit: February 05, 2019, 11:31:56 PM by niko »
Offline jerryyyyy
  • Win NT 10.0
  • Firefox 65.0
« Reply #10 on: February 06, 2019, 03:58:18 AM »
Thanks, I think I understand how it works now.  I appreciate the detailed help.
Do you actually use AAG_WeatherCenter?  Or just WeatherDisplay?  I have a funny page that shows up when it boot or when I look for updates.
Offline niko
  • syzygy
  • Global Moderator
  • Win 7/Srvr 2008R2
« Reply #11 on: February 06, 2019, 04:00:50 AM »
I only have WD, just trying to help out  :)
Offline jerryyyyy
  • Win NT 10.0
  • Firefox 65.0
« Reply #12 on: February 06, 2019, 04:13:02 AM »
Thanks, FYI this is where the station and observatory are located in NorCal:
https://www.wunderground.com/personal-weather-station/dashboard?ID=KCASTANF2&cm_ven=localwx_pwsdash#history
Cheers
JY
