Author Topic: update due to change to https by NOAA for metar downloads  (Read 1176 times)
  • Davis VP2
  • Chrome 71.0.3578.98
    • Weather Display
« on: February 04, 2019, 10:46:25 PM »
new update of WD
or use direct
http://www.weather-display.com/downloadfiles/cronmetardownload.zip
(only affected if you have set to use http for the metar download)
« Last Edit: February 05, 2019, 12:04:02 AM by Weather Display »
Offline GlosWeather
  • Gloucestershire, UK
    • glosweather.com
Re: update due to change to https by noaa for metar downloads
« Reply #1 on: February 04, 2019, 11:30:19 PM »
Great timing, thanks Brian.
Offline Harry
  • Union City, CA USA
  • Firefox 65.0
    • Union City, CA Weather
Re: update due to change to https by NOAA for metar downloads
« Reply #2 on: February 06, 2019, 04:58:15 AM »
Thanks, Brian.
Offline teal
  • Davis vantage pro 2 windows 10
  • Norfolk England
  • Win 7/Srvr 2008R2
    • Weather At Wilney Green Norfolk
« Reply #3 on: February 06, 2019, 12:06:42 PM »
  Hi, I take it that you just down load, & then open it into WD ?.
   many thanks.
  teal.
Offline Svenni
  • Moss in Norway
  • Chrome 70.0.3538.102
    • Refsnesbakken Borettslag
« Reply #4 on: February 06, 2019, 12:22:58 PM »
Yes download the zip fil and unzip. Move the file to your weather display folder.
Svenni
Offline teal
  • Norfolk England
  • Win 7/Srvr 2008R2
« Reply #5 on: February 06, 2019, 03:54:17 PM »
  Hi, thanks for just making sure cheers.
  teal.
Offline TechScribe
  • Davis Weather Vue
  • Kirkland, Washington USA
  • Chrome 72.0.3626.109
    • KirklandWeather.com
« Reply #6 on: February 17, 2019, 06:28:03 PM »
My METAR data stopped working in early February, presumably caused by this change. I'm running the latest build of WD which already has this updated .exe file from the ZIP file mentioned in this thread.
I'm still am not getting the custom field %weatherreport% populated from the downloaded METAR for observed weather reading.  The only files now available for download for my three METAR sites are TAF files. I've gone through every possible combination of check boxes in WD to make this work, including it is is a TAF metar.  I use the custom %weatherreport% in wxlocal30.html and it's the 37th entry in the array and it's now just a null value.
Is there a different custom field we're now supposed to use or some combination of settings?
I'm using KSEA.TAF, KBFI.TAF, and KPAE .TAF and have KSEA.TAF set as the Use this metar as icon/icon conditions. I also tried entering this as .TXT extensions even though the downloaded files are .TAF. Settings I've also tried adjusting:
  • Use the metar to update wd's main weather condition report
  • Save as a .txt file as well as a .met file
  • It is a ASOS/SYNOP metar
  • It is a taf metar
  • Davis VP2
    • Weather Display
« Reply #7 on: February 17, 2019, 06:31:07 PM »
are you sure you have the latest cronmetardownload.exe version?
what is the modified date/time on that file?
try grabbing it from
Offline TechScribe
  • Davis Weather Vue
« Reply #8 on: February 17, 2019, 07:34:39 PM »
The one in c:\wdisplay is actually newer:  2/5/2019 8:10 AM.  The one in the ZIP is 2/4/2019 11:10 AM. Both same size. I've copied over the one from ZIP just to be sure.
The TAF files are downloading, but wx30.html still getting a null value for %weatherreport%.
  • Davis VP2
    • Weather Display
« Reply #9 on: February 17, 2019, 07:37:15 PM »
I am not sure why the metar is not downloading for you when it is for me and others
what windows version?
Offline TechScribe
  • Davis Weather Vue
« Reply #10 on: February 17, 2019, 07:44:35 PM »
Unfortunately, it's not just me.  Another site I help with has the same issue with metars from a different part of the US. We both broke in early February.
Both on Windows 10 Pro
Microsoft Windows [Version 10.0.17763.253]
Weather Display
10-37S Build 90 -12 Feb 2019
Offline TechScribe
  • Davis Weather Vue
« Reply #11 on: February 17, 2019, 07:49:23 PM »
To be clear, we're getting TAF files downloaded, but that's it.
Can you verify which check boxes should be set on the METAR Downloads tab to process these coming down as TAF?
And should we specificy KXXX.txt or KXXX.taf for the station IDs?
Thanks!
  • Davis VP2
    • Weather Display
« Reply #12 on: February 17, 2019, 07:50:03 PM »
testing here
I get
151: HTTP protocol error. 404 Not Found.
https://aviationweather.gov/adds/dataserver_current/httpparam?datasource=tafs&requestType=retrieve&format=xml&mostRecentForEachStation=true&hoursBeforeNow=2&stationString=KSEA
Downloading TAF:https://aviationweather.gov/adds/dataserver_current/httpparam?datasource=tafs&requestType=retrieve&format=xml&mostRecentForEachStation=true&hoursBeforeNow=2&stationString=KSEA
Downloading to :C:\wdisplayprogram\metar\KSEA.taf
Offline TechScribe
  • Davis Weather Vue
« Reply #13 on: February 17, 2019, 07:56:57 PM »
I'm not seeing the 151 error. Those links open fine for me directly in a Chrome browser. What WD is putting in the metar folder is a .taf file (KSEA.taf):
Contents:
KSEA 171747Z 1718/1824 19003KT P6SM BKN015 OVC020 FM171900 VRB03KT P6SM BKN020 OVC060 FM172100 34006KT P6SM SCT025 BKN040 FM180000 35003KT P6SM SCT025 BKN040 FM180700 11004KT P6SM SCT015 BKN030 FM181200 11004KT P6SM SCT010 BKN025 FM182100 23004KT P6SM SCT025 OVC060
  • Davis VP2
    • Weather Display
« Reply #14 on: February 17, 2019, 07:57:18 PM »
ops
I had put in the list KSEA.TAF instead of KSEA.TXT
now it works
*** version Metar Download vers 2.0
Next file HTTP metar station download
https://tgftp.nws.noaa.gov/data/observations/metar/decoded/KSEA.TXT
Downloading to :C:\wdisplayprogram\metar\KSEA.met
final download setting=C:\wdisplayprogram\metar\KSEA.met
Doing metar download now
Attempting to connect to server.
OK
Socket connection established.
Starting secure channel handshake.
Enabling TLS versions: TLS1.2 TLS1.1 TLS1.0
Cipher Suites:
    TLS_KRB5_EXPORT_WITH_RC2_CBC_40_MD5 (0x002a);
    TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 (0xc02c);
    TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256 (0xc02b);
    TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030);
    TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 (0xc02f);
    TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 (0x009f);
    TLS_DHE_RSA_WITH_AES_128_GCM_SHA256 (0x009e);
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA384 (0xc024);
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA256 (0xc023);
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028);
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027);
    TLS_ECDHE_ECDSA_WITH_AES_256_CBC_SHA (0xc00a);
    TLS_ECDHE_ECDSA_WITH_AES_128_CBC_SHA (0xc009);
    TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014);
    TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013);
    TLS_RSA_WITH_AES_256_GCM_SHA384 (0x009d);
    TLS_RSA_WITH_AES_128_GCM_SHA256 (0x009c);
    TLS_RSA_WITH_AES_256_CBC_SHA256 (0x003d);
    TLS_RSA_WITH_AES_128_CBC_SHA256 (0x003c);
    TLS_RSA_WITH_AES_256_CBC_SHA (0x0035);
    TLS_RSA_WITH_AES_128_CBC_SHA (0x002f)
Sending 174 bytes of handshake data.
Receiving 1330 bytes of handshake data.
Receiving 2048 bytes of handshake data.
Receiving 802 bytes of handshake data.
Selected TLS Version: TLS1.2
Selected Cipher Suite: TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 (0xc030)
Receiving 342 bytes of handshake data.
Sending 126 handshake bytes.
Receiving 51 bytes of handshake data.
OK
OU=Domain Control Validated, CN=dev.ncep.noaa.gov
C=US, S=Arizona, L=Scottsdale, O="GoDaddy.com, Inc.", OU=http://certs.godaddy.com/repository/, CN=Go Daddy Secure Certificate Authority - G2
Negotiated SSL parameters: Protocol: TLS1.2 Cipher: AES Cipher strength: 256 Hash: SHA384 Hash strength: 0 Key exchange: ECDH Ephemeral RSA Key exchange strength: 256
OK
Connected
OK
OK
Doing TAF metar download now
OK
Cipher Suites:
Sending 175 bytes of handshake data.
Receiving 2007 bytes of handshake data.
Receiving 242 bytes of handshake data.
OK
C=US, S=Maryland, L=College Park, O=National Oceanic and Atmospheric Administration NOAA, CN=weather.gov
C=US, O=DigiCert Inc, CN=DigiCert SHA2 Secure Server CA
OK
Connected
OK
OK
Finished downloading metars
what shows in your metardownloadlog.txt
