raspberry pi and OS WMR89
Hi All ,
Could you confirm if the WMR89 will run with a raspberry pi version 2 please , ive looked at the config.txt and cant see any code for this type of station.
Darren
I could try and add support I guess
Hi Brian ,
It would be appreciated , but if its a big job then dont worry about it , i`ll keep on running it from my pc .
Or if it can be added on the next update maybe ? or i could get a Pi 3 if its easier to add it to that code ?
Darren
I will try and get working on my raspberry pi3 first
nothing is ever easy with linux
I was able to get the com port to open
after following this
https://domoticproject.com/configuring-wmr89-weewx/
but the next problem is the needed baud rate of 128000 is not standard
and using stty -F /dev/tty USB0 128000
produces an invalid error
no worries Brian , thanks for trying tho :slight_smile:
