Connecting to Environdata Weather Maestro
Hi Brian
Still not quite there by the look of things.
Baro & solar not reporting on WD display.
thanks
Scott
R
← end
#13 found 48
raw data →
2019/02/25 07:02:16 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
Sensor Name Model Value Unit
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000000.75 km/h
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000080.48 Degrees
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000084.49 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000018.63 Degrees
← end
**temperature decode = +000018.63
#13 found 57
raw data →
5 "Rain Gauge " (RG12): +000000.00 mm
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000014.1 Watts/m2
← end
**raw solar data +0000014.1 Watts/m2
**raw solar data >+0000014.1<-
#13 found 58
raw data →
7 "exBP " (BP40): +0000415.0 hPa
← end
#13 found 56
raw data →
8 "exSolar " ( ): +0000000.0 V
← end
#13 found 60
raw data →
9 "exExt " ( ): +000000000 Units
← end
#13 found 55
raw data →
10 " " ( ): +000000000
← end
#13 found 55
raw data →
11 " " ( ): +000000000
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001031.96 hPa
← end
***raw baro +001031.96 hPa
#13 found 59
raw data →
13 "ex(VCos) " ( ): +000000.00 km/h
← end
#13 found 59
raw data →
14 "ex(VSin) " ( ): +000000.00 km/h
← end
#13 found 57
raw data →
15 "exEvap " ( ): +000000.00 mm
← end
#13 found 55
raw data →
16 " " ( ): +000000000
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): +00000.157
← end
#13 found 55
raw data →
18 "WDIR Sine " ( ): +00000.987
← end
#13 found 55
raw data →
19 " " ( ): +000000000
← end
#13 found 55
raw data →
20 " " ( ): +000000000
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.69 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000040.76 mA
← end
#13 found 56
raw data →
23 "Solar Voltage " ( ): +000000.00 V
← end
#13 found 57
raw data →
24 "Charge Current " ( ): +000000.00 mA
← end
#13 found 59
raw data →
25 "Peak Wind Gust " ( ): +000002.00 km/h
← end
#13 found 59
raw data →
26 "Inst. Wind Speed " ( ): +000001.00 km/h
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000080.88 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.12 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.74 km/h
← end
#13 found 57
raw data →
30 "9am Rain Total " ( ): +000000.00 mm
← end
#13 found 57
raw data →
31 "Evaporation " ( ): +00000.000 mm
← end
#13 found 62
raw data →
32 "Communications " ( ): +000001.00 Minutes
← end
I think I know what is wrong
try a new test .zip update download again
(‘thankyou, next’)
Hi Brian
Sorry, still seems to be the same.
Debug file below.
I’ve also extracted the raw input from the weather station in case that’s useful to you. I did this via a terminal window, not wd, so should be exactly what the station is sending.
Scott
raw data →
R
← end
#13 found 48
raw data →
2019/02/26 06:51:17 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000001.00 km/h
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000080.43 Degrees
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000081.50 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000019.17 Degrees
← end
**temperature decode = +000019.17
#13 found 57
raw data →
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000015.8 Watts/m2
← end
**raw solar data +0000015.8 Watts/m2
**raw solar data >0000015.8<-
sucess solar data
#13 found 58
raw data →
← end
#13 found 56
raw data →
← end
#13 found 60
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001034.00 hPa
← end
***raw baro +001034.00 hPa
***raw baro2 001034.00hPa
*barometer data >001034.00h<
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): +00000.158
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.94 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000040.09 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000079.57 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.16 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.99 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
#13 found 5
r
2019/02/26 23:25:35 Title “Bunya:304BP.dl3”
3 "Relative Humidity " (RH40): +000083.65 %
4 "Air Temperature " (TA40): +000018.46 Degrees
6 "Solar Radiation " (SR41): +0000000.0 Watts/m2
12 "Barometric Pressure " (BP40): +001014.96 hPa
21 "Battery Voltage " ( ): +000012.73 V
25 "Peak Wind Gust " ( ): +000001.00 km/h
OK, I see the problem re the barometer
see here
there is the h being picked up
use another new .zip test update, same url, and it should work now
Success! The barometer is coming through a-ok now!
Still nothing on the solar though. Here’s the latest debug file.
Also, the system remembers that it’s talking to a WM2000 ok, but doesn’t seem to initiate comms until I go to setup… station… and hit ok without changing anything. Because I’ve been troubleshooting each time I haven’t waited more than a couple of minutes for it to initiate comms so perhaps I’ve just been impatient but it seems a bit odd.
Many thanks!
Scott
Daylight saving not in use
Loaded all time records
Connected OK to com port 8
#13 found 1
raw data →
← end
#13 found 38
raw data →
;Environdata DL3000 V1.67 2010/04/12
← end
#13 found 23
raw data →
;%01000000% 1111-0304
← end
#13 found 5
raw data →
R
← end
#13 found 48
raw data →
2019/02/27 07:06:16 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000000.45 km/h
← end
#13 found 62
raw data →
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000075.82 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000020.26 Degrees
← end
**temperature decode = +000020.26
#13 found 57
raw data →
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000027.5 Watts/m2
← end
**raw solar data +0000027.5 Watts/m2
**raw solar data >0000027.5<-
sucess solar data
#13 found 58
raw data →
← end
#13 found 56
raw data →
← end
#13 found 60
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001047.96 hPa
← end
***raw baro +001047.96 hPa
***raw baro2 001047.96hPa
*barometer data >001047.96<
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000013.04 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000016.61 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.07 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.44 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
32 "Communications " ( ): +000000.00 Minutes
← end
#13 found 5
solar data should be working
ie as it says
success solar data
also make sure the switch is on under control panel, solar setup
I will check on the start up…
I see the start up issue
use this update
and see if the solar shows up now above the windspeed dial?
The startup issue has been fixed, thanks.
Solar still indicating 0 - rather troublesome isn’t it! I’m pleased you seem to like a challenge (as do I!)
Scott
R
← end
#13 found 48
raw data →
2019/02/27 19:51:46 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000000.35 km/h
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000103.91 Degrees
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000062.99 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000022.13 Degrees
← end
**temperature decode = +000022.13
#13 found 57
raw data →
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000016.6 Watts/m2
← end
**raw solar data +0000016.6 Watts/m2
**raw solar data >0000016.6<-
sucess solar data
#13 found 58
raw data →
7 "Baro " (BP40): +0001008.1 hPa
← end
#13 found 55
raw data →
8 " " ( ): +0000000.0
← end
#13 found 55
raw data →
9 " " ( ): +0000000.0
← end
#13 found 55
raw data →
← end
#13 found 63
raw data →
11 "Solar Radiation " (SR41): +0000016.6 Watts/m2
← end
sucess solar data
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +0001008.1 hPa
← end
***raw baro +0001008.1 hPa
***raw baro2 0001008.1hPa
*barometer data >0001008.1<
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): -00000.249
← end
#13 found 55
raw data →
18 "WDIR Sine " ( ): +00000.968
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.65 V
← end
#13 found 57
raw data →
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
26 "Inst. Wind Speed " ( ): +000000.00 km/h
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000103.46 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): -000000.09 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.34 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
its not clear exactly where solar is showing 0
On the main screen, above the dials. Photos attached. It’s also configured in a scroll bar that shows 0. And it’s publishing to wunderground, but also as 0. (Basically 0 everywhere apart from in the debug file :frowning: )
Scott
wd_photos.pdf (213 KB)
it looks like you have WD set to show solar %
and you might not have the lat/long set correctly in control panel, solar setup
email me your wdisplay.ini settings file
Here 'tis
WDISPLAY.zip (9.34 KB)
Hi Brian, looks like rainfall isn’t coming through correctly either. Debug file shows ‘current’ rain and ‘since 9am’ rain and neither displaying on main WD screen.
Scott
I see with your settings you have some things set wrong
you need to set the sensor number to use back to 0
for the solar sensor in a jar and untick to use that to overide UV
also the lat/long and time zone do not look correct for the max solar for lat/long
re the rain, try another .zip test update, and I have added some debug code around that
Thanks. Debug file follows. I’m happy to have solar in w/m2 rather than %, so will have a play with that later on.
Scott
#13 found 5
raw data ->ATE0
← end
#13 found 22
raw data →
AT+CMGL=“REC UNREAD”
← end
#13 found 2
raw data →
← end
#13 found 38
raw data →
← end
#13 found 23
raw data →
← end
#13 found 5
raw data →
R
← end
#13 found 48
raw data →
2019/03/01 06:34:46 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000211.30 Degrees
← end
#13 found 56
raw data →
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000020.43 Degrees
← end
**temperature decode = +000020.43
#13 found 57
raw data →
← end
**rain decode +000000.00 mm
**rain decode2 ->+000000.00<-
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000030.8 Watts/m2
← end
**raw solar data +0000030.8 Watts/m2
**raw solar data >0000030.8<-
sucess solar data
#13 found 58
raw data →
7 "Baro " (BP40): +0001009.0 hPa
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 63
raw data →
11 "Solar Radiation " (SR41): +0000030.8 Watts/m2
← end
sucess solar data
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +0001009.0 hPa
← end
***raw baro +0001009.0 hPa
***raw baro2 0001009.0hPa
*barometer data >0001009.0<
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): -00000.844
← end
#13 found 55
raw data →
18 "WDIR Sine " ( ): -00000.535
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.59 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000017.06 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000210.90 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): -000000.85 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): -000000.53 km/h
← end
#13 found 57
raw data →
30 "9am Rain Total " ( ): +000007.00 mm
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
the rain should be being picked up ok now
Thanks Brian, rain is working fine now.
Still no joy with the solar, seems to be reading zero in w/m2 too so I don’t think it’s a lat/long problem. I added this tag %VPsolar% to main screen and it’s also zero.
Any ideas?
thanks!
email (dont post on forum) me your wdisplay.ini settings file and I will do some testing/checking
I think I have the solar fixed now
Yep, that’s nailed it!
Thank you so much Brian.
I think I’ve got everything worked spot-on now.
I really appreciate all your help.
Scott
