Connecting to Environdata Weather Maestro
Hi Brian
Still not quite there by the look of things.
Baro & solar not reporting on WD display.
thanks
Scott
R
← end
#13 found 48
raw data →
2019/02/25 07:02:16 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
Sensor Name Model Value Unit
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000000.75 km/h
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000080.48 Degrees
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000084.49 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000018.63 Degrees
← end
**temperature decode = +000018.63
#13 found 57
raw data →
5 "Rain Gauge " (RG12): +000000.00 mm
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000014.1 Watts/m2
← end
**raw solar data +0000014.1 Watts/m2
**raw solar data >+0000014.1<-
#13 found 58
raw data →
7 "exBP " (BP40): +0000415.0 hPa
← end
#13 found 56
raw data →
8 "exSolar " ( ): +0000000.0 V
← end
#13 found 60
raw data →
9 "exExt " ( ): +000000000 Units
← end
#13 found 55
raw data →
10 " " ( ): +000000000
← end
#13 found 55
raw data →
11 " " ( ): +000000000
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001031.96 hPa
← end
***raw baro +001031.96 hPa
#13 found 59
raw data →
13 "ex(VCos) " ( ): +000000.00 km/h
← end
#13 found 59
raw data →
14 "ex(VSin) " ( ): +000000.00 km/h
← end
#13 found 57
raw data →
15 "exEvap " ( ): +000000.00 mm
← end
#13 found 55
raw data →
16 " " ( ): +000000000
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): +00000.157
← end
#13 found 55
raw data →
18 "WDIR Sine " ( ): +00000.987
← end
#13 found 55
raw data →
19 " " ( ): +000000000
← end
#13 found 55
raw data →
20 " " ( ): +000000000
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.69 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000040.76 mA
← end
#13 found 56
raw data →
23 "Solar Voltage " ( ): +000000.00 V
← end
#13 found 57
raw data →
24 "Charge Current " ( ): +000000.00 mA
← end
#13 found 59
raw data →
25 "Peak Wind Gust " ( ): +000002.00 km/h
← end
#13 found 59
raw data →
26 "Inst. Wind Speed " ( ): +000001.00 km/h
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000080.88 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.12 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.74 km/h
← end
#13 found 57
raw data →
30 "9am Rain Total " ( ): +000000.00 mm
← end
#13 found 57
raw data →
31 "Evaporation " ( ): +00000.000 mm
← end
#13 found 62
raw data →
32 "Communications " ( ): +000001.00 Minutes
← end
