Connecting to Environdata Weather Maestro
That mostly worked, thanks.
Reports RH at 90% despite it being 0.1% (sensor seems broken, still look into that). Looks to be an error in that tag per the debug file, will past latest version below.
Not critical, but does this mean I can also pick up fields like Battery Voltage and display them?
Many thanks!
Scott
aw data ->R
2019/01/30 20:23:10 Title “BP:304.dl3”
Sensor Name Model Value Unit
1 "Wind Speed " (WS45): +000001.20 km/h
2 "Wind Direction " (WD<- end
raw data ->45): +000000.00<- end
raw data → Degrees
3 "Re<- end
raw data ->lative Humidity " (RH40): -000000.10 %<- end
raw data →
4 "Air Te<- end
raw data ->mperature " (TA40): +000025.76 Degrees ← end
raw data →
5 "Rain Gauge "<- end
raw data → (RG12): +001000.00 mm<- end
raw data →
6 "Solar Radiation " (SR41): +0000000.0<- end
raw data → Watts/m2
← end
raw data → 17 "WDIR Cosine " ( ): +00001.000 ← end
raw data →
18 "WDIR Si<- end
raw data ->ne " ( ): +00000.000 ← end
raw data →
21 "Battery Vol<- end
raw data ->tage " ( ): +000012.62 V<- end
raw data →
22 "Load Current " ( ← end
raw data ->): +000043.46 mA
← end
raw data →
23 "Solar Voltage " ( ): +000001.34 V<- end
raw data →
24 "Charge C<- end
raw data ->urrent " ( ): +000000.00 mA<- end
raw data →
25 "Peak Wind Gust " (<- end
raw data → ): +000002.00 km/h<- end
raw data →
26 "Inst. Wind Speed " ( ): +000001.00 k<- end
raw data ->m/h
← end
raw data →
27 "Inst. Wind Direction " ( ): +000000.00 Degre<- end
raw data ->es
← end
raw data ->28 "N/-S Wind Sp (VCos) " ( ): +000001.20 km/h<- end
raw data →
29 "E/-W Wind Sp ← end
raw data ->(VSin) " ( ): +000000.00 km/h<- end
raw data →
30 "9am Rain Total " ( )<- end
raw data ->: +010000.00 mm
← end
raw data → 31 "Evaporation " ( ): +nan mm<- end
raw data →
32 "Communica<- end
raw data ->tions " ( ): +000001.00 Minutes<- end
raw data →
← end
so the data is coming through now to WD?
I have not yet added parsing of the battery voltage but I can do that (and then you can add a custom tag to the main screen for that )
Yes, that’s right, data is coming through ok. Except for humidity which is constantly reporting 90% - doesn’t match input data.
Thank you!
try a new update
humidity should work now and so should battery volts (e.g %batteryvolts% custom tag)
Thanks Brian, that looks to be working ok now. I’ve got a few sensor issues to repair before I know that everything works 100%, but everything that is working on the Maestro is now reporting accurately on WD, so that’s great!
Thanks for your help, much appreciated!
Scott
Hi Brian
I’ve got the sensors working now, but doesn’t look like the data is coming through correctly for solar or barometric. Here’s the relevant lines:
raw data →
6 "Solar Radiation ← end
raw data → " (SR41): +0000000.0 Wat<- end
raw data ->ts/m2
7 "Barom<- end
raw data →
12 "Barometric ← end
raw data ->Pressure " (BP40): +000599.96 hPa<- end
(the solar is zero as it’s night time, and the barometric I still need to work out the calibration factors for - but both are working)
Also, each time I start the software I need to re-select the station type. Should the software remember that?
Scott
try this update
Hi Brian
Not quite right yet, here’s how the solar looks in the debug file:
raw data →
6 "Solar Radiation " (SR41): +000014<- end
raw data ->5.0 Watts/m2
7 ← end
The barometric is also still split:
raw data →
12 "Barometric Pressure " (BP4<- end
raw data ->0): +000000.00 hPa
← end
try another update re the barometer
and also post the whole data debug window
Thanks Brian
Barometer still 1013.0 on the summary screen.
I can’t tell if solar is coming through ok as it’s dark out.
Thanks for all your assistance.
Here’s the debug file for a full read cycle:
R
#13 found 50
2019/02/23 22:42:16 Title “Bunya:304BP.dl3”
#13 found 109
#13 found 168
1 "Wind Speed " (WS45): +000002.05 km/h
raw data ->R
2 "Wind Direction<- end
raw data → " (WD45): +000080.48 ← end
raw data ->Degrees<- end
#13 found 1
2 "Wind Direction " (WD45): +000080.48 Degrees
raw data →
3 "Relative Humidity " (RH40): +000057.32 %<- end
#13 found 1
raw data →
4 "Air Tem<- end
raw data ->perature " (TA40): +000022.10 Degrees ← end
#13 found 1
4 "Air Temperature " (TA40): +000022.10 Degrees
raw data →
5 "Rain Gauge<- end
raw data → " (RG12): +000000.00 mm<- end
#13 found 1
5 "Rain Gauge " (RG12): +000000.00 mm
raw data →
6 "Solar Radiation " (SR<- end
raw data ->41): +0000000.0 Watts/m2<- end
**raw solar data 41): +0000000.0 Watt
#13 found 1
6 "Solar Radiation " (SR41): +0000000.0 Watts/m2
raw data →
7 "exBP " (BP40): +0000415.0 hPa<- end
#13 found 1
raw data →
8 "exSola<- end
raw data ->r " ( ): +0000000.0 V<- end
#13 found 1
8 "exSolar " ( ): +0000000.0 V
raw data →
9 "exExt " ← end
raw data ->( ): +000000000 Units<- end
#13 found 1
9 "exExt " ( ): +000000000 Units
raw data →
10 " ← end
raw data → " ( ): +000000000 ← end
#13 found 1
10 " " ( ): +000000000
raw data →
11 " " ( ): +<- end
#13 found 11
11 " " ( ): +000000000
raw data ->000000000
← end
raw data → 12 "Barometric Pressure " (BP40): +001014.96 hPa<- end
#13 found 1
raw data →
13 "ex(VCos) ← end
raw data → " ( ): +000000.00 km/h<- end
#13 found 1
13 "ex(VCos) " ( ): +000000.00 km/h
raw data →
14 "ex(VSin) " ( ← end
#13 found 19
14 "ex(VSin) " ( ): +000000.00 km/h
raw data ->): +000000.00 km/h
← end
raw data → 15 "exEvap " ( ): +<- end
#13 found 13
15 "exEvap " ( ): +000000.00 mm
raw data ->000000.00 mm
← end
raw data → 16 " " ( ): +000000000 ← end
#13 found 1
raw data →
17 "WDIR Cosine ← end
raw data → " ( ): +00000.157 ← end
#13 found 1
17 "WDIR Cosine " ( ): +00000.157
raw data →
18 "WDIR Sine " ( )<- end
#13 found 14
18 "WDIR Sine " ( ): +00000.987
raw data ->: +00000.987
← end
raw data → 19 " " ( ): +000<- end
#13 found 8
19 " " ( ): +000000000
raw data ->000000
20<- end
raw data → " " ( ): +000000000 ← end
#13 found 1
20 " " ( ): +000000000
raw data →
21 "<- end
raw data ->Battery Voltage " ( ): +000012.35 V<- end
#13 found 1
21 "Battery Voltage " ( ): +000012.35 V
raw data →
22 "Load Current ← end
raw data → " ( ): +000042.08 mA<- end
#13 found 1
22 "Load Current " ( ): +000042.08 mA
raw data →
23 "Solar Voltage " ( ): +000<- end
#13 found 9
23 "Solar Voltage " ( ): +000000.00 V
raw data ->000.00 V
24<- end
raw data → "Charge Current " ( ): +000000.00 mA<- end
#13 found 1
24 "Charge Current " ( ): +000000.00 mA
raw data →
25 "Peak Wind Gust ← end
raw data → " ( ): +000003.00 km/h<- end
#13 found 1
25 "Peak Wind Gust " ( ): +000003.00 km/h
raw data →
26 "Inst. Wind Speed " ( ): ← end
raw data ->+000001.00 km/h<- end
#13 found 1
26 "Inst. Wind Speed " ( ): +000001.00 km/h
raw data →
27 "Inst. Wind Direction " ( ): +000<- end
#13 found 15
27 "Inst. Wind Direction " ( ): +000080.88 Degrees
raw data ->080.88 Degrees
← end
raw data → 28 "N/-S Wind Sp (VCos) " ( ): +000000.3<- end
#13 found 7
28 "N/-S Wind Sp (VCos) " ( ): +000000.32 km/h
raw data ->2 km/h
29 "E<- end
raw data ->/-W Wind Sp (VSin) " ( ): +000002.02 km/h<- end
#13 found 1
29 "E/-W Wind Sp (VSin) " ( ): +000002.02 km/h
raw data →
30 "9am Rain Total ← end
raw data → " ( ): +000000.00 mm<- end
#13 found 1
30 "9am Rain Total " ( ): +000000.00 mm
raw data →
31 "Evaporation " ( ): +00000<- end
#13 found 8
31 "Evaporation " ( ): +00000.000 mm
raw data ->.000 mm
32 ← end
raw data → "Communications " ( ): +000001.00<- end
#13 found 9
32 "Communications " ( ): +000001.00 Minutes
raw data → Minutes
← end
OK, we are making progress
try another update
Thanks Brian
Still doesn’t seem to be picking up readings for barometer or solar - and battery seems to have dropped off now too.
Scott
debug file:
R
#13 found 50
2019/02/24 17:23:16 Title “Bunya:304BP.dl3”
#13 found 109
#13 found 168
1 "Wind Speed " (WS45): +000002.25 km/h
raw data ->R
2 "Wind Direction " (WD45): +000080.48 Degrees<- end
#13 found 1
raw data →
3 "Relative Humidity " (RH40):<- end
raw data → +000043.49 %<- end
#13 found 1
3 "Relative Humidity " (RH40): +000043.49 %
raw data →
4 "Air Te<- end
raw data ->mperature " (TA40): +000026.56 Degrees<- end
#13 found 2
4 "Air Temperature " (TA40): +000026.56 Degrees
raw data →
5 "Rain Gauge<- end
#13 found 1
raw data →
raw data ->41): +0000038.3 Watts/m2<- end
**raw solar data 41): +0000038.3 Watt
#13 found 1
6 "Solar Radiation " (SR41): +0000038.3 Watts/m2
raw data →
#13 found 1
raw data →
8 "exSola<- end
#13 found 1
raw data →
9 "exExt "<- end
raw data → ( ): +000000000 Units<- end
#13 found 1
raw data →
10 " " ( ← end
raw data → ): +000000000 ← end
#13 found 1
raw data →
11 " " ( ): +<- end
#13 found 11
← end
raw data → 12 "Barometric Pressure " (BP40): +001060.96 hPa<- end
#13 found 1
raw data →
13 "ex(VCos) ← end
#13 found 1
raw data →
#13 found 19
← end
raw data → 15 "exEvap " ( ): +000000.00 mm<- end
#13 found 1
raw data →
← end
#13 found 1
raw data →
#13 found 1
raw data →
#13 found 14
← end
raw data → 19 " " ( ): +000000000 ← end
#13 found 1
raw data →
2<- end
raw data ->0 " " ( ): +000000000 ← end
#13 found 1
raw data →
21 "Battery Voltage<- end
raw data → " ( ): +000013.18 V<- end
#13 found 1
21 "Battery Voltage " ( ): +000013.18 V
raw data →
22 "Load Current " ( ): ← end
raw data ->+000039.65 mA<- end
#13 found 1
22 "Load Current " ( ): +000039.65 mA
raw data →
#13 found 9
raw data ->000.00 V
24<- end
#13 found 1
raw data →
raw data → " ( ): +000004.00 km/h<- end
#13 found 1
25 "Peak Wind Gust " ( ): +000004.00 km/h
raw data →
raw data ->+000003.00 km/h<- end
#13 found 1
26 "Inst. Wind Speed " ( ): +000003.00 km/h
raw data →
#13 found 15
2<- end
raw data ->8 "N/-S Wind Sp (VCos) " ( ): +000000.35 km/h<- end
#13 found 1
28 "N/-S Wind Sp (VCos) " ( ): +000000.35 km/h
raw data →
29 "E<- end
raw data ->/-W Wind Sp (VSin) " ( ): +000002.22 km/h<- end
#13 found 1
29 "E/-W Wind Sp (VSin) " ( ): +000002.22 km/h
raw data →
#13 found 1
raw data →
31 "Evaporation " ( ): +0000<- end
#13 found 9
raw data ->0.000 mm
32 ← end
raw data → "Communications " ( ): +000001.0<- end
#13 found 10
raw data ->0 Minutes
← end
humm, I don’t think you have the correct update
try the test download again?
yes, you’re right. something went wrong there. I can see from the debug file that it’s locating the baro reading now, but still showing 1013.0 on the wd screen.
can’t tell what solar is doing, night time again.
latest debug file below, thanks again!
#13 found 5
raw data →
R
← end
#13 found 48
raw data →
2019/02/24 23:18:17 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000001.70 km/h
← end
#13 found 62
raw data →
2 "Wind Direction " (WD45): +000080.43 Degrees
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000062.99 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000021.66 Degrees
← end
**temperature decode = +000021.66
#13 found 57
raw data →
← end
#13 found 63
raw data →
← end
**raw solar data +0000000.0 Watts/m2
**raw solar data >+0000000.0 ←
#13 found 58
raw data →
← end
#13 found 56
raw data →
← end
#13 found 60
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 58
raw data →
← end
***raw baro +001014.96 hPa
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
17 "WDIR Cosine " ( ): +00000.158
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.45 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000041.20 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
26 "Inst. Wind Speed " ( ): +000002.00 km/h
← end
#13 found 62
raw data →
27 "Inst. Wind Direction " ( ): +000079.57 Degrees
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.27 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000001.68 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
step by step we will get there
I will add a bit more debug info
I see what is wrong now…a good brew of coffee helped
download a new test update, ready now :slight_smile:
Hi Brian
Still not quite there by the look of things.
Baro & solar not reporting on WD display.
thanks
Scott
R
← end
#13 found 48
raw data →
2019/02/25 07:02:16 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000000.75 km/h
← end
#13 found 62
raw data →
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000084.49 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000018.63 Degrees
← end
**temperature decode = +000018.63
#13 found 57
raw data →
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000014.1 Watts/m2
← end
**raw solar data +0000014.1 Watts/m2
**raw solar data >+0000014.1<-
#13 found 58
raw data →
← end
#13 found 56
raw data →
← end
#13 found 60
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001031.96 hPa
← end
***raw baro +001031.96 hPa
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.69 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000040.76 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
25 "Peak Wind Gust " ( ): +000002.00 km/h
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.12 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.74 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
I think I know what is wrong
try a new test .zip update download again
(‘thankyou, next’)
Hi Brian
Sorry, still seems to be the same.
Debug file below.
I’ve also extracted the raw input from the weather station in case that’s useful to you. I did this via a terminal window, not wd, so should be exactly what the station is sending.
Scott
raw data →
R
← end
#13 found 48
raw data →
2019/02/26 06:51:17 Title “Bunya:304BP.dl3”
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
1 "Wind Speed " (WS45): +000001.00 km/h
← end
#13 found 62
raw data →
← end
#13 found 56
raw data →
3 "Relative Humidity " (RH40): +000081.50 %
← end
#13 found 63
raw data →
4 "Air Temperature " (TA40): +000019.17 Degrees
← end
**temperature decode = +000019.17
#13 found 57
raw data →
← end
#13 found 63
raw data →
6 "Solar Radiation " (SR41): +0000015.8 Watts/m2
← end
**raw solar data +0000015.8 Watts/m2
**raw solar data >0000015.8<-
sucess solar data
#13 found 58
raw data →
← end
#13 found 56
raw data →
← end
#13 found 60
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 58
raw data →
12 "Barometric Pressure " (BP40): +001034.00 hPa
← end
***raw baro +001034.00 hPa
***raw baro2 001034.00hPa
*barometer data >001034.00h<
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 57
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 55
raw data →
← end
#13 found 56
raw data →
21 "Battery Voltage " ( ): +000012.94 V
← end
#13 found 57
raw data →
22 "Load Current " ( ): +000040.09 mA
← end
#13 found 56
raw data →
← end
#13 found 57
raw data →
← end
#13 found 59
raw data →
← end
#13 found 59
raw data →
← end
#13 found 62
raw data →
← end
#13 found 59
raw data →
28 "N/-S Wind Sp (VCos) " ( ): +000000.16 km/h
← end
#13 found 59
raw data →
29 "E/-W Wind Sp (VSin) " ( ): +000000.99 km/h
← end
#13 found 57
raw data →
← end
#13 found 57
raw data →
← end
#13 found 62
raw data →
← end
#13 found 5
r
2019/02/26 23:25:35 Title “Bunya:304BP.dl3”
3 "Relative Humidity " (RH40): +000083.65 %
4 "Air Temperature " (TA40): +000018.46 Degrees
21 "Battery Voltage " ( ): +000012.73 V
25 "Peak Wind Gust " ( ): +000001.00 km/h
OK, I see the problem re the barometer
see here
there is the h being picked up
use another new .zip test update, same url, and it should work now
