Author Topic: Connecting to Environdata Weather Maestro  (Read 1411 times)
Offline magrathea
  • Win 7/Srvr 2008R2
  • Chrome 72.0.3626.109
Re: Connecting to Environdata Weather Maestro
« Reply #15 on: February 23, 2019, 12:30:00 PM »
Thanks Brian
Barometer still 1013.0 on the summary screen.
I can't tell if solar is coming through ok as it's dark out.
Thanks for all your assistance.
Here's the debug file for a full read cycle:
> R
#13 found 50
2019/02/23 22:42:16    Title "Bunya:304BP.dl3"
#13 found 109
Sensor Name                       Model   Value      Unit
#13 found 168
  1    "Wind Speed              " (WS45): +000002.05 km/h
raw data ->R
  2    "Wind Direction<- end
raw data ->          " (WD45): +000080.48 <- end
raw data ->Degrees<- end
#13 found 1
  2    "Wind Direction          " (WD45): +000080.48 Degrees
raw data ->
  3    "Relative Humidity       " (RH40): +000057.32 %<- end
#13 found 1
raw data ->
  4    "Air Tem<- end
raw data ->perature         " (TA40): +000022.10 Degrees <- end
#13 found 1
  4    "Air Temperature         " (TA40): +000022.10 Degrees
raw data ->
  5    "Rain Gauge<- end
raw data ->              " (RG12): +000000.00 mm<- end
#13 found 1
  5    "Rain Gauge              " (RG12): +000000.00 mm
raw data ->
  6    "Solar Radiation         " (SR<- end
raw data ->41): +0000000.0 Watts/m2<- end
**raw solar data 41): +0000000.0 Watt
#13 found 1
  6    "Solar Radiation         " (SR41): +0000000.0 Watts/m2
raw data ->
  7    "exBP                    " (BP40): +0000415.0 hPa<- end
#13 found 1
raw data ->
  8    "exSola<- end
raw data ->r                 " (    ): +0000000.0 V<- end
#13 found 1
  8    "exSolar                 " (    ): +0000000.0 V
raw data ->
  9    "exExt                   " <- end
raw data ->(    ): +000000000 Units<- end
#13 found 1
  9    "exExt                   " (    ): +000000000 Units
raw data ->
  10   "                <- end
raw data ->        " (    ): +000000000 <- end
#13 found 1
  10   "                        " (    ): +000000000
raw data ->
  11   "                        " (    ): +<- end
#13 found 11
  11   "                        " (    ): +000000000
raw data ->000000000
 <- end
raw data -> 12   "Barometric Pressure     " (BP40): +001014.96 hPa<- end
#13 found 1
raw data ->
  13   "ex(VCos)    <- end
raw data ->            " (    ): +000000.00 km/h<- end
#13 found 1
  13   "ex(VCos)                " (    ): +000000.00 km/h
raw data ->
  14   "ex(VSin)                " (    <- end
#13 found 19
  14   "ex(VSin)                " (    ): +000000.00 km/h
raw data ->): +000000.00 km/h
<- end
raw data ->  15   "exEvap                  " (    ): +<- end
#13 found 13
  15   "exEvap                  " (    ): +000000.00 mm
raw data ->000000.00 mm
 <- end
raw data -> 16   "                        " (    ): +000000000 <- end
#13 found 1
raw data ->
  17   "WDIR Cosine  <- end
raw data ->           " (    ): +00000.157 <- end
#13 found 1
  17   "WDIR Cosine             " (    ): +00000.157
raw data ->
  18   "WDIR Sine               " (    )<- end
#13 found 14
  18   "WDIR Sine               " (    ): +00000.987
raw data ->: +00000.987
<- end
raw data ->  19   "                        " (    ): +000<- end
#13 found 8
  19   "                        " (    ): +000000000
raw data ->000000
  20<- end
raw data ->   "                        " (    ): +000000000 <- end
#13 found 1
  20   "                        " (    ): +000000000
raw data ->
  21   "<- end
raw data ->Battery Voltage         " (    ): +000012.35 V<- end
#13 found 1
  21   "Battery Voltage         " (    ): +000012.35 V
raw data ->
  22   "Load Current       <- end
raw data ->     " (    ): +000042.08 mA<- end
#13 found 1
  22   "Load Current            " (    ): +000042.08 mA
raw data ->
  23   "Solar Voltage           " (    ): +000<- end
#13 found 9
  23   "Solar Voltage           " (    ): +000000.00 V
raw data ->000.00 V
  24<- end
raw data ->   "Charge Current          " (    ): +000000.00 mA<- end
#13 found 1
  24   "Charge Current          " (    ): +000000.00 mA
raw data ->
  25   "Peak Wind Gust <- end
raw data ->         " (    ): +000003.00 km/h<- end
#13 found 1
  25   "Peak Wind Gust          " (    ): +000003.00 km/h
raw data ->
  26   "Inst. Wind Speed        " (    ): <- end
raw data ->+000001.00 km/h<- end
#13 found 1
  26   "Inst. Wind Speed        " (    ): +000001.00 km/h
raw data ->
  27   "Inst. Wind Direction    " (    ): +000<- end
#13 found 15
  27   "Inst. Wind Direction    " (    ): +000080.88 Degrees
raw data ->080.88 Degrees
<- end
raw data ->  28   "N/-S Wind Sp (VCos)     " (    ): +000000.3<- end
#13 found 7
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.32 km/h
raw data ->2 km/h
  29   "E<- end
raw data ->/-W Wind Sp (VSin)     " (    ): +000002.02 km/h<- end
#13 found 1
  29   "E/-W Wind Sp (VSin)     " (    ): +000002.02 km/h
raw data ->
  30   "9am Rain Total      <- end
raw data ->    " (    ): +000000.00 mm<- end
#13 found 1
  30   "9am Rain Total          " (    ): +000000.00 mm
raw data ->
  31   "Evaporation             " (    ): +00000<- end
#13 found 8
  31   "Evaporation             " (    ): +00000.000 mm
raw data ->.000 mm
  32 <- end
raw data ->  "Communications          " (    ): +000001.00<- end
#13 found 9
  32   "Communications          " (    ): +000001.00 Minutes
raw data -> Minutes
> <- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
« Reply #16 on: February 23, 2019, 05:40:47 PM »
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #17 on: February 24, 2019, 07:06:20 AM »
Thanks Brian
Still doesn't seem to be picking up readings for barometer or solar - and battery seems to have dropped off now too.
Scott
debug file:
> R
#13 found 50
2019/02/24 17:23:16    Title "Bunya:304BP.dl3"
#13 found 109
#13 found 168
  1    "Wind Speed              " (WS45): +000002.25 km/h
raw data ->R
  2    "Wind Direction          " (WD45): +000080.48 Degrees<- end
#13 found 1
raw data ->
  3    "Relative Humidity       " (RH40):<- end
raw data -> +000043.49 %<- end
#13 found 1
  3    "Relative Humidity       " (RH40): +000043.49 %
raw data ->
  4    "Air Te<- end
raw data ->mperature         " (TA40): +000026.56 Degrees<- end
#13 found 2
  4    "Air Temperature         " (TA40): +000026.56 Degrees
raw data ->
  5    "Rain Gauge<- end
#13 found 1
raw data ->
raw data ->41): +0000038.3 Watts/m2<- end
**raw solar data 41): +0000038.3 Watt
#13 found 1
  6    "Solar Radiation         " (SR41): +0000038.3 Watts/m2
raw data ->
#13 found 1
raw data ->
  8    "exSola<- end
#13 found 1
raw data ->
  9    "exExt                   "<- end
raw data -> (    ): +000000000 Units<- end
#13 found 1
raw data ->
  10   "                        " (  <- end
raw data ->  ): +000000000 <- end
#13 found 1
raw data ->
  11   "                        " (    ): +<- end
#13 found 11
 <- end
raw data -> 12   "Barometric Pressure     " (BP40): +001060.96 hPa<- end
#13 found 1
raw data ->
  13   "ex(VCos)    <- end
#13 found 1
raw data ->
#13 found 19
<- end
raw data ->  15   "exEvap                  " (    ): +000000.00 mm<- end
#13 found 1
raw data ->
 <- end
#13 found 1
raw data ->
#13 found 1
raw data ->
#13 found 14
<- end
raw data ->  19   "                        " (    ): +000000000 <- end
#13 found 1
raw data ->
  2<- end
raw data ->0   "                        " (    ): +000000000 <- end
#13 found 1
raw data ->
  21   "Battery Voltage<- end
raw data ->         " (    ): +000013.18 V<- end
#13 found 1
  21   "Battery Voltage         " (    ): +000013.18 V
raw data ->
  22   "Load Current            " (    ): <- end
raw data ->+000039.65 mA<- end
#13 found 1
  22   "Load Current            " (    ): +000039.65 mA
raw data ->
#13 found 9
raw data ->000.00 V
  24<- end
#13 found 1
raw data ->
raw data ->         " (    ): +000004.00 km/h<- end
#13 found 1
  25   "Peak Wind Gust          " (    ): +000004.00 km/h
raw data ->
raw data ->+000003.00 km/h<- end
#13 found 1
  26   "Inst. Wind Speed        " (    ): +000003.00 km/h
raw data ->
#13 found 15
  2<- end
raw data ->8   "N/-S Wind Sp (VCos)     " (    ): +000000.35 km/h<- end
#13 found 1
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.35 km/h
raw data ->
  29   "E<- end
raw data ->/-W Wind Sp (VSin)     " (    ): +000002.22 km/h<- end
#13 found 1
  29   "E/-W Wind Sp (VSin)     " (    ): +000002.22 km/h
raw data ->
#13 found 1
raw data ->
  31   "Evaporation             " (    ): +0000<- end
#13 found 9
raw data ->0.000 mm
  32 <- end
raw data ->  "Communications          " (    ): +000001.0<- end
#13 found 10
raw data ->0 Minutes
> <- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #18 on: February 24, 2019, 08:46:36 AM »
humm, I don't think you have the correct update
try the test download again?
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #19 on: February 24, 2019, 01:01:10 PM »
yes, you're right.  something went wrong there.  I can see from the debug file that it's locating the baro reading now, but still showing 1013.0 on the wd screen.
can't tell what solar is doing, night time again.
latest debug file below, thanks again!
#13 found 5
raw data ->
> R
<- end
#13 found 48
raw data ->
2019/02/24 23:18:17    Title "Bunya:304BP.dl3"
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  1    "Wind Speed              " (WS45): +000001.70 km/h
<- end
#13 found 62
raw data ->
  2    "Wind Direction          " (WD45): +000080.43 Degrees
<- end
#13 found 56
raw data ->
  3    "Relative Humidity       " (RH40): +000062.99 %
<- end
#13 found 63
raw data ->
  4    "Air Temperature         " (TA40): +000021.66 Degrees
<- end
**temperature decode = +000021.66
#13 found 57
raw data ->
<- end
#13 found 63
raw data ->
<- end
**raw solar data +0000000.0 Watts/m2
**raw solar data >+0000000.0 <-
#13 found 58
raw data ->
<- end
#13 found 56
raw data ->
<- end
#13 found 60
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 58
raw data ->
<- end
***raw baro +001014.96 hPa
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
  17   "WDIR Cosine             " (    ): +00000.158
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 56
raw data ->
  21   "Battery Voltage         " (    ): +000012.45 V
<- end
#13 found 57
raw data ->
  22   "Load Current            " (    ): +000041.20 mA
<- end
#13 found 56
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  26   "Inst. Wind Speed        " (    ): +000002.00 km/h
<- end
#13 found 62
raw data ->
  27   "Inst. Wind Direction    " (    ): +000079.57 Degrees
<- end
#13 found 59
raw data ->
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.27 km/h
<- end
#13 found 59
raw data ->
  29   "E/-W Wind Sp (VSin)     " (    ): +000001.68 km/h
<- end
#13 found 57
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 62
raw data ->
<- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #20 on: February 24, 2019, 05:52:51 PM »
step by step we will get there
I will add a bit more debug info
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #21 on: February 24, 2019, 05:58:04 PM »
I see what is wrong now..a good brew of coffee helped
download a new test update, ready now :)
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #22 on: February 25, 2019, 11:40:15 AM »
Hi Brian
Still not quite there by the look of things.
Baro & solar not reporting on WD display.
thanks
Scott
R
<- end
#13 found 48
raw data ->
2019/02/25 07:02:16    Title "Bunya:304BP.dl3"
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  1    "Wind Speed              " (WS45): +000000.75 km/h
<- end
#13 found 62
raw data ->
<- end
#13 found 56
raw data ->
  3    "Relative Humidity       " (RH40): +000084.49 %
<- end
#13 found 63
raw data ->
  4    "Air Temperature         " (TA40): +000018.63 Degrees
<- end
**temperature decode = +000018.63
#13 found 57
raw data ->
<- end
#13 found 63
raw data ->
  6    "Solar Radiation         " (SR41): +0000014.1 Watts/m2
<- end
**raw solar data +0000014.1 Watts/m2
**raw solar data >+0000014.1<-
#13 found 58
raw data ->
<- end
#13 found 56
raw data ->
<- end
#13 found 60
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 58
raw data ->
  12   "Barometric Pressure     " (BP40): +001031.96 hPa
<- end
***raw baro +001031.96 hPa
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 56
raw data ->
  21   "Battery Voltage         " (    ): +000012.69 V
<- end
#13 found 57
raw data ->
  22   "Load Current            " (    ): +000040.76 mA
<- end
#13 found 56
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 59
raw data ->
  25   "Peak Wind Gust          " (    ): +000002.00 km/h
<- end
#13 found 59
raw data ->
<- end
#13 found 62
raw data ->
<- end
#13 found 59
raw data ->
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.12 km/h
<- end
#13 found 59
raw data ->
  29   "E/-W Wind Sp (VSin)     " (    ): +000000.74 km/h
<- end
#13 found 57
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 62
raw data ->
<- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #23 on: February 25, 2019, 06:26:01 PM »
I think I know what is wrong
try a new test .zip update download again
('thankyou, next')
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #24 on: February 26, 2019, 01:10:07 PM »
Hi Brian
Sorry, still seems to be the same.
Debug file below.
I've also extracted the raw input from the weather station in case that's useful to you.  I did this via a terminal window, not wd, so should be exactly what the station is sending.
Scott
raw data ->
> R
<- end
#13 found 48
raw data ->
2019/02/26 06:51:17    Title "Bunya:304BP.dl3"
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  1    "Wind Speed              " (WS45): +000001.00 km/h
<- end
#13 found 62
raw data ->
<- end
#13 found 56
raw data ->
  3    "Relative Humidity       " (RH40): +000081.50 %
<- end
#13 found 63
raw data ->
  4    "Air Temperature         " (TA40): +000019.17 Degrees
<- end
**temperature decode = +000019.17
#13 found 57
raw data ->
<- end
#13 found 63
raw data ->
  6    "Solar Radiation         " (SR41): +0000015.8 Watts/m2
<- end
**raw solar data +0000015.8 Watts/m2
**raw solar data >0000015.8<-
sucess solar data
#13 found 58
raw data ->
<- end
#13 found 56
raw data ->
<- end
#13 found 60
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 58
raw data ->
  12   "Barometric Pressure     " (BP40): +001034.00 hPa
<- end
***raw baro +001034.00 hPa
***raw baro2 001034.00hPa
*barometer data >001034.00h<
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 56
raw data ->
  21   "Battery Voltage         " (    ): +000012.94 V
<- end
#13 found 57
raw data ->
  22   "Load Current            " (    ): +000040.09 mA
<- end
#13 found 56
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 62
raw data ->
<- end
#13 found 59
raw data ->
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.16 km/h
<- end
#13 found 59
raw data ->
  29   "E/-W Wind Sp (VSin)     " (    ): +000000.99 km/h
<- end
#13 found 57
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 62
raw data ->
<- end
#13 found 5
> r
2019/02/26 23:25:35    Title "Bunya:304BP.dl3"
  3    "Relative Humidity       " (RH40): +000083.65 %
  4    "Air Temperature         " (TA40): +000018.46 Degrees
  21   "Battery Voltage         " (    ): +000012.73 V
  25   "Peak Wind Gust          " (    ): +000001.00 km/h
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 72.0.3626.119
    • Weather Display
« Reply #25 on: February 26, 2019, 05:36:19 PM »
OK, I see the problem re the barometer
see here
there is the h being picked up
use another new .zip test update, same url, and it should work now
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #26 on: February 26, 2019, 08:56:00 PM »
Success! The barometer is coming through a-ok now!
Still nothing on the solar though.  Here's the latest debug file.
Also, the system remembers that it's talking to a WM2000 ok, but doesn't seem to initiate comms until I go to setup.. station.. and hit ok without changing anything.  Because I've been troubleshooting each time I haven't waited more than a couple of minutes for it to initiate comms so perhaps I've just been impatient but it seems a bit odd.
Many thanks!
Scott
Doing checking of time zone calculation
Daylight saving not in use
Loaded all time records
Connected OK to com port 8
#13 found 1
raw data ->
<- end
#13 found 38
raw data ->
;Environdata DL3000 V1.67 2010/04/12
<- end
#13 found 23
raw data ->
;%01000000% 1111-0304
<- end
#13 found 5
raw data ->
> R
<- end
#13 found 48
raw data ->
2019/02/27 07:06:16    Title "Bunya:304BP.dl3"
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  1    "Wind Speed              " (WS45): +000000.45 km/h
<- end
#13 found 62
raw data ->
<- end
#13 found 56
raw data ->
  3    "Relative Humidity       " (RH40): +000075.82 %
<- end
#13 found 63
raw data ->
  4    "Air Temperature         " (TA40): +000020.26 Degrees
<- end
**temperature decode = +000020.26
#13 found 57
raw data ->
<- end
#13 found 63
raw data ->
  6    "Solar Radiation         " (SR41): +0000027.5 Watts/m2
<- end
**raw solar data +0000027.5 Watts/m2
**raw solar data >0000027.5<-
sucess solar data
#13 found 58
raw data ->
<- end
#13 found 56
raw data ->
<- end
#13 found 60
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 58
raw data ->
  12   "Barometric Pressure     " (BP40): +001047.96 hPa
<- end
***raw baro +001047.96 hPa
***raw baro2 001047.96hPa
*barometer data >001047.96<
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 56
raw data ->
  21   "Battery Voltage         " (    ): +000013.04 V
<- end
#13 found 57
raw data ->
  22   "Load Current            " (    ): +000016.61 mA
<- end
#13 found 56
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 62
raw data ->
<- end
#13 found 59
raw data ->
  28   "N/-S Wind Sp (VCos)     " (    ): +000000.07 km/h
<- end
#13 found 59
raw data ->
  29   "E/-W Wind Sp (VSin)     " (    ): +000000.44 km/h
<- end
#13 found 57
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 62
raw data ->
  32   "Communications          " (    ): +000000.00 Minutes
<- end
#13 found 5
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #27 on: February 26, 2019, 09:05:05 PM »
solar data should be working
ie as it says
success solar data
also make sure the switch is on under control panel, solar setup
I will check on the start up...
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #28 on: February 26, 2019, 09:46:13 PM »
I see the start up issue
use this update
and see if the solar shows up now above the windspeed dial?
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #29 on: February 27, 2019, 09:53:05 AM »
The startup issue has been fixed, thanks.
Solar still indicating 0 - rather troublesome isn't it!  I'm pleased you seem to like a challenge (as do I!)
Scott
R
<- end
#13 found 48
raw data ->
2019/02/27 19:51:46    Title "Bunya:304BP.dl3"
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  1    "Wind Speed              " (WS45): +000000.35 km/h
<- end
#13 found 62
raw data ->
  2    "Wind Direction          " (WD45): +000103.91 Degrees
<- end
#13 found 56
raw data ->
<- end
#13 found 63
raw data ->
  4    "Air Temperature         " (TA40): +000022.13 Degrees
<- end
**temperature decode = +000022.13
#13 found 57
raw data ->
<- end
#13 found 63
raw data ->
  6    "Solar Radiation         " (SR41): +0000016.6 Watts/m2
<- end
**raw solar data +0000016.6 Watts/m2
**raw solar data >0000016.6<-
sucess solar data
#13 found 58
raw data ->
  7    "Baro                    " (BP40): +0001008.1 hPa
<- end
#13 found 55
raw data ->
  8    "                        " (    ): +0000000.0
<- end
#13 found 55
raw data ->
  9    "                        " (    ): +0000000.0
<- end
#13 found 55
raw data ->
<- end
#13 found 63
raw data ->
  11   "Solar Radiation         " (SR41): +0000016.6 Watts/m2
<- end
sucess solar data
#13 found 58
raw data ->
  12   "Barometric Pressure     " (BP40): +0001008.1 hPa
<- end
***raw baro +0001008.1 hPa
***raw baro2 0001008.1hPa
*barometer data >0001008.1<
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
  17   "WDIR Cosine             " (    ): -00000.249
<- end
#13 found 55
raw data ->
  18   "WDIR Sine               " (    ): +00000.968
<- end
#13 found 55
raw data ->
<- end
#13 found 55
raw data ->
<- end
#13 found 56
raw data ->
  21   "Battery Voltage         " (    ): +000012.65 V
<- end
#13 found 57
raw data ->
<- end
#13 found 56
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 59
raw data ->
<- end
#13 found 59
raw data ->
  26   "Inst. Wind Speed        " (    ): +000000.00 km/h
<- end
#13 found 62
raw data ->
  27   "Inst. Wind Direction    " (    ): +000103.46 Degrees
<- end
#13 found 59
raw data ->
  28   "N/-S Wind Sp (VCos)     " (    ): -000000.09 km/h
<- end
#13 found 59
raw data ->
  29   "E/-W Wind Sp (VSin)     " (    ): +000000.34 km/h
<- end
#13 found 57
raw data ->
<- end
#13 found 57
raw data ->
<- end
#13 found 62
raw data ->
<- end
