Author Topic: Connecting to Environdata Weather Maestro  (Read 1099 times)
Offline magrathea
  • Win 7/Srvr 2008R2
  • Chrome 71.0.3578.98
« on: January 28, 2019, 10:57:24 AM »
I'm trying to connect WD with a Maestro.  If I connect as an Environdata Weather Master 2000, the system appears to communicate ok (green light on data received and quality).  The debug file seems to be providing sensible data, however none of this is reported as 'current conditions' - e.g. current temperature reports as 13degrees consistently.
It appears that the data from the Maestro isn't being mapped to the correct fields in WD.  Is this something I can edit?
Thanks!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Re: Connecting to Environdata Weather Maestro
« Reply #1 on: January 28, 2019, 05:48:09 PM »
can you post what shows under view , debug info?
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #2 on: January 29, 2019, 10:10:34 AM »
Yep, here it is:
Connected OK to com port 8
raw data ->R
2019/01/29 20:27:11    Title "BP:304.dl3"
Sensor Name                       Model   Value      Unit
  1    "Wind Speed              " (WS45): +000000.85 km/h
  2    "Wind Di<- end
raw data ->rection          " (WD45): +000000.00 Degrees<- end
raw data ->
  3    "Relative Humidity       " (RH40): -000000<- end
raw data ->.10 %
  4    <- end
raw data ->"Air Temperature         " (TA40): +000024.83 Degrees <- end
raw data ->
  5    "Rain Gauge        <- end
raw data ->      " (RG12): +001000.00 mm<- end
raw data ->
  6    "Solar Radiation         " (SR41): +00<- end
raw data ->00000.0 Watts/m2<- end
raw data ->
  17   "WDIR Cosine             " ( <- end
raw data ->   ): +00001.000 <- end
raw data ->
  18   "WDIR Sine               " (    ): +00000.000 <- end
raw data ->
  21   "Battery Voltage         " (    ): +0<- end
raw data ->00012.64 V<- end
raw data ->
  22   "Load Current            <- end
raw data ->" (    ): +000044.12 mA<- end
raw data ->
  23   "Solar Voltage           " (    ): +000001.1<- end
raw data ->8 V<- end
raw data ->
  24   "Charge Current          " (    ): +000000.00 mA<- end
raw data ->
  25   "Peak <- end
raw data ->Wind Gust          " (    ): +000001.00 km/h<- end
raw data ->
  26   "Inst. Wind Speed        <- end
raw data ->" (    ): +000001.00 km/h<- end
raw data ->
  27   "Inst. Wind Direction    " (    ): +000000.0<- end
raw data ->0 Degrees
<- end
raw data ->  28   "N/-S Wind Sp (VCos)     " (    ): +000000.85 km/h<- end
raw data ->
  29   "E/-W W<- end
raw data ->ind Sp (VSin)     " (    ): +000000.00 km/h<- end
raw data ->
  30   "9am Rain T<- end
raw data ->otal          " (    ): +010000.00 mm<- end
raw data ->
  31   "Evaporation             " (   <- end
raw data -> ):       +nan mm<- end
raw data ->
  32   "Communications          " (    ): +000001.00 Minu<- end
raw data ->tes
> <- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #3 on: January 29, 2019, 09:18:18 PM »
It looks like a different format
that what it used to be
I will need to add an option to use this format and then you can test?
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #4 on: January 30, 2019, 01:12:27 AM »
Yep, brilliant, thanks!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #5 on: January 30, 2019, 02:38:07 AM »
first beta
(extract to where you have WD installed (exit WD first))
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #6 on: January 30, 2019, 11:19:38 AM »
That mostly worked, thanks.
Reports RH at 90% despite it being 0.1% (sensor seems broken, still look into that).  Looks to be an error in that tag per the debug file, will past latest version below.
Not critical, but does this mean I can also pick up fields like Battery Voltage and display them?
Many thanks!
Scott
aw data ->R
2019/01/30 20:23:10    Title "BP:304.dl3"
  1    "Wind Speed              " (WS45): +000001.20 km/h
  2    "Wind Direction          " (WD<- end
raw data ->45): +000000.00<- end
raw data -> Degrees
  3    "Re<- end
raw data ->lative Humidity       " (RH40): -000000.10 %<- end
raw data ->
  4    "Air Te<- end
raw data ->mperature         " (TA40): +000025.76 Degrees <- end
raw data ->
  5    "Rain Gauge              "<- end
raw data -> (RG12): +001000.00 mm<- end
raw data ->
  6    "Solar Radiation         " (SR41): +0000000.0<- end
raw data -> Watts/m2
<- end
raw data ->  17   "WDIR Cosine             " (    ): +00001.000 <- end
raw data ->
  18   "WDIR Si<- end
raw data ->ne               " (    ): +00000.000 <- end
raw data ->
  21   "Battery Vol<- end
raw data ->tage         " (    ): +000012.62 V<- end
raw data ->
  22   "Load Current            " (    <- end
raw data ->): +000043.46 mA
<- end
raw data ->
  23   "Solar Voltage           " (    ): +000001.34 V<- end
raw data ->
  24   "Charge C<- end
raw data ->urrent          " (    ): +000000.00 mA<- end
raw data ->
  25   "Peak Wind Gust          " (<- end
raw data ->    ): +000002.00 km/h<- end
raw data ->
  26   "Inst. Wind Speed        " (    ): +000001.00 k<- end
raw data ->m/h
<- end
raw data ->
  27   "Inst. Wind Direction    " (    ): +000000.00 Degre<- end
raw data ->es
  <- end
raw data ->28   "N/-S Wind Sp (VCos)     " (    ): +000001.20 km/h<- end
raw data ->
  29   "E/-W Wind Sp <- end
raw data ->(VSin)     " (    ): +000000.00 km/h<- end
raw data ->
  30   "9am Rain Total          " (    )<- end
raw data ->: +010000.00 mm
<- end
raw data ->  31   "Evaporation             " (    ):       +nan mm<- end
raw data ->
  32   "Communica<- end
raw data ->tions          " (    ): +000001.00 Minutes<- end
raw data ->
> <- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #7 on: January 30, 2019, 06:13:30 PM »
so the data is coming through now to WD?
I have not yet added parsing of the battery voltage but I can do that (and then you can add a custom tag  to the main screen for that )
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #8 on: January 30, 2019, 10:13:08 PM »
Yes, that's right, data is coming through ok.  Except for humidity which is constantly reporting 90% - doesn't match input data.
Thank you!
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #9 on: January 30, 2019, 10:24:46 PM »
try a new update
humidity should work now and so should battery volts (e.g %batteryvolts% custom tag)
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #10 on: January 31, 2019, 10:44:52 AM »
Thanks Brian, that looks to be working ok now.  I've got a few sensor issues to repair before I know that everything works 100%, but everything that is working on the Maestro is now reporting accurately on WD, so that's great!
Thanks for your help, much appreciated!
Scott
Offline magrathea
  • Win 7/Srvr 2008R2
  • Chrome 72.0.3626.109
« Reply #11 on: February 21, 2019, 12:56:47 PM »
Hi Brian
I've got the sensors working now, but doesn't look like the data is coming through correctly for solar or barometric.  Here's the relevant lines:
raw data ->
  6    "Solar Radiation  <- end
raw data ->       " (SR41): +0000000.0 Wat<- end
raw data ->ts/m2
  7    "Barom<- end
raw data ->
  12   "Barometric <- end
raw data ->Pressure     " (BP40): +000599.96 hPa<- end
(the solar is zero as it's night time, and the barometric I still need to work out the calibration factors for - but both are working)
Also, each time I start the software I need to re-select the station type.  Should the software remember that?
Scott
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
Offline magrathea
  • Win 7/Srvr 2008R2
« Reply #13 on: February 23, 2019, 12:52:34 AM »
Hi Brian
Not quite right yet, here's how the solar looks in the debug file:
raw data ->
  6    "Solar Radiation         " (SR41): +000014<- end
raw data ->5.0 Watts/m2
  7    <- end
The barometric is also still split:
raw data ->
  12   "Barometric Pressure     " (BP4<- end
raw data ->0): +000000.00 hPa
<- end
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #14 on: February 23, 2019, 01:41:15 AM »
try another update re the barometer
and also post the whole data debug window
