Author Topic: SFTP Timing Out - Not Able To Upload Files on WD 10.37S89  (Read 382 times)
Online Weather Display
  • Davis VP2
  • New Zealand
  • Win NT 10.0
  • Chrome 71.0.3578.98
    • Weather Display
Re: SFTP Timing Out - Not Able To Upload Files on WD 10.37S89
« Reply #15 on: January 28, 2019, 05:19:52 PM »
if you set the times different to send the files in the 2nd server, to the main one, does that help?
Offline jnardone_pdx
  • iOS 12.1.3
  • Safari 12.0
« Reply #16 on: January 28, 2019, 06:35:09 PM »
I will need to try later.  I’m on the road the next few days.  What I did try was is completely disable the primary ftp client.  That is the first set of pictures I attached.  That definitely did not work.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #17 on: January 28, 2019, 06:50:37 PM »
in checking my code, I am not using the SFTP option for the 2nd server in the grouped upload
so that is the problem
are you able to make your SFTP server available for me to test?
  • iOS 12.1.3
  • Safari 12.0
« Reply #18 on: January 28, 2019, 07:04:42 PM »
Unfortunately not since it is an internal only system.  Since the primary works flawlessly, I’m assuming the just enabling for the 2nd connection would work.  I could try Wednesday evening, pacific time.
  • Davis VP2
  • New Zealand
  • Win NT 10.0
    • Weather Display
« Reply #19 on: January 28, 2019, 07:05:43 PM »
its a complete new set of code that  I need to write
I will try my best and then you can test
unless someeone else has  a SFTP server that I can access to test
