I have not seen the email yet???
You should have the email now, thanks
Resent, fingers crossed !
yes
but
I want the actual file not the log
Have now emailed you some metar files Brian. Thanks
I have fixed this now in the latest update
Thanks Brian, metar download working fine now.
Probably unrelated, but metars stopped being downloaded after 1350 UTC today. The tafs are still coming in, showing that the download procedure is still working. Metars are still available from the NOAA website so its not clear what the problem is.
Exactly the same here. (Coincidentally, I updated to 10.37S90 this morning, but that’s obviously not the reason!)
you can check yourself
the WD metar download program has not changed
NOAA have changed something - metardownloadlog says “object moved” - perhaps it should now be secure (https) Brian?
it looks like a change by noaa then
(nothing I have changed)
the url to get the metar might have changed or similar
actually if you put the url into a web browser it changes to https
so that is probably all the change that is needed by me to make
let me try that
All good again - thanks Brian - up to date - also get the TAF downloaded too now.
Bristol / Lulsgate , United Kingdom (EGGD) 51-23N 002-43W
Feb 04, 2019 - 01:50 PM EST / 2019.02.04 1850 UTC
Wind: from the SW (220 degrees) at 6 MPH (5 KT):0
Visibility: greater than 7 mile(s):0
Temperature: 42 F (6 C)
Dew Point: 42 F (6 C)
Relative Humidity: 100%
Pressure (altimeter): 30.09 in. Hg (1019 hPa)
ob: EGGD 041850Z AUTO 22005KT 9999 NCD 06/06 Q1019
cycle: 19
Yes, thanks Brian!
Thanks all for publizing the problem, sourcing the fault and fixing so promptly. Hopefully this will draw a line under this particular topic !
Brian, not working for me. LDZD.TXT or LDSP.TXT. Croatian airports…what is problem?
its not clear if you have updated to use the latest cronmetardownload.exe version
(that is only used if you have set to use http download in the metar download setup)
I have latest update and cronmetardownload.exe 2.0, but it not working. Metar folder is empty.
