Author Topic: google maps API key  (Read 1098 times)
Offline tobydude
  • Norway
  • Win 7/Srvr 2008R2
  • Chrome 70.0.3538.102
    • Fjærvoll Værstasjon
google maps API key
« on: January 24, 2019, 08:22:34 AM »
Hi.
For the suncalc in Leuven template, where should I put the google map API key?
In which file should the key go?
thanks.
Offline wvdkuil
  • Wim van der Kuil
  • Leuven Belgium CET
  • Mac OS X 10.13.6
  • Chrome 71.0.3578.98
Re: google maps API key
« Reply #1 on: January 24, 2019, 09:04:41 AM »
Hi.
thanks.
There is nothing you can do.  Those scripts do not run on your website, you can not change / enhance them at all.
They run in an iFrame, in your case similar to this http://suncalc.net/#/68.6465,14.4378,8/2019.01.24/09:58
The developer of  suncalc is working on it, see the pop-up which shows in that link
Quote
Note (Oct 2018): I'm aware of the broken map (see this article for more context). Stay tuned — I'm working on a new version!
Last year June, the script was deleted from the template-downloads because of the Google changes.
Offline tobydude
  • Norway
  • Win 7/Srvr 2008R2
« Reply #2 on: January 24, 2019, 06:12:51 PM »
Hi. Thanks for answering.
I have mailed the scripts autor to help. :)
The suncalc at vindpropell.no, now:  http://vindpropell.no/weather2/index.php?p=06&lang=no
« Last Edit: January 24, 2019, 06:29:01 PM by tobydude »
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #3 on: January 24, 2019, 06:28:38 PM »
The script runs at my website, but I can not put in the right Google maps API key.
I have got the right key, but dont know whwre to put it. .)
Tis is the script with the old key, but how to access?  https://maps.googleapis.com/maps/api/js?key=AIzaSyCZX07EcLk3WSSkq6JdIN2c1H5a_lW83V0
Your page http://vindpropell.no/weather2/index.php?p=06&lang=no
loads in an iFrame    http://suncalc.net/    that is another ones website not yours.
The API key should be inserted in that script in the suncalc website, only the author of suncalc can do that.
Offline tobydude
  • Norway
  • Win 7/Srvr 2008R2
« Reply #4 on: January 24, 2019, 06:30:43 PM »
Ok. I understand. Have written the author.
wi´ll see. Thanks.
Offline wvdkuil
  • Wim van der Kuil
  • Mac OS X 10.13.6
« Reply #5 on: January 24, 2019, 06:56:38 PM »
wi´ll see. Thanks.
What you could do in the meantime
1. Copy the full page html of http://suncalc.net/
2. Change the links to the javascripts and css to the full URL (by adding http://suncalc.net/)
3. Insert your own API key in the link to google maps at line 17
4. Put the html on your website, example testsc.html
5. Run it with  http://vindpropell.no/testsc.html
6. change the link in weather2/inc/suncalc_frame.php line 38 from
Code: [Select]
$url            = 'http://suncalc.net'.$extra;to
Code: [Select]
$url            = 'http://vindpropell.no/testsc.html';
I tested it, and it seems to work with a valid API-key for the site it is running from, in your case the key must be valid for vindpropell.no
Attached the version which works.
Offline tobydude
  • Norway
  • Android 8.0.0
  • Chrome 71.0.3578.99
« Reply #6 on: January 25, 2019, 12:08:06 PM »
Thanks. Got it to work now. Importen to use right wildcard in the making of the  URL.
« Last Edit: January 25, 2019, 12:12:54 PM by tobydude »
