is there a com port showing up in windows device manager?
(i.e to then be able to select in WD)
you might need to first install the software that comes with the station to get the com port driver installed
what shows in WD under view,debug info?
the low barometer reading showing in WD might be a clue…have you set any barometer offset in WD?
